Pocket GPS World :: View topic - TT4.40 Ipaq and GPS wired
Hi204e
PostPosted: Tue Jun 07, 2005 3:34 pm    Post subject: TT4.40 Ipaq and GPS wired Reply with quote
I've TT 4.4 and I have some problem to connect with my gps wired.
TT doesn't find any signal.
This is strange because if I try to use TT GPS (applet) I can configure my gps and I have signal.
Is there some registry in TT that I must modify to use the correct port and receiver ?
Thanks for your support.
lbendlin
PostPosted: Tue Jun 07, 2005 5:10 pm    Post subject: Reply with quote
TTN4 does explicitly NOT support CF GPS receivers. It may work if you select "other BT receiver" but this is not guaranteed.
Lutz
TomTom/TeleAtlas NAVTEQ
Hi204e
PostPosted: Wed Jun 08, 2005 11:32 am    Post subject: Reply with quote
Thanks for the tips.
I've tried and I see that can function.
But now I have a little problem: how can I tell to use serial port com1 at BT ?
I see that default port for BT is com8.
should I change registry ? What ?
lbendlin
PostPosted: Wed Jun 08, 2005 1:45 pm    Post subject: Reply with quote
once you selected "Other BT" it will present you with a list of COPM ports it found on the device. Your COM1: should be listed too.
Lutz
Hi204e
PostPosted: Wed Jun 08, 2005 2:48 pm    Post subject: Reply with quote
Yes, it's listed, but TT didn't use that.
TT continue to set BT to default port. Confused Crying or Very sad
22.064 (26 Jun 24)
