Pocket GPS World :: View topic - Tom Tom Go Safety Cameras
HAMPIE
PostPosted: Wed Jun 08, 2005 9:23 am    Post subject: Tom Tom Go Safety Cameras Reply with quote
Sad I have recently purchased the latest TomTom Go 300 and successfully downloaded the Pocket GPS safety camera database to my PC. I unzipped the file and copied all the contents into the GB Map on the SD Card. I then tried for several hours to enable the POI for the safety cameras with no success - I went in through "Manage POI" on the Go 300 but could not find any speedcamera info. I am unsure as to how to bring up the database onto the GB map and are not sure as to the name of the POI camera database to enter into the Go 300.
I know it should work fine but would be grateful if anyone could inform me step by step as to how to achieve this. Many thanks.
gingernut777
PostPosted: Wed Jun 08, 2005 9:43 am    Post subject: Reply with quote
You could use this,
http://www.pocketgpsworld.com/modules.php?name=Forums&file=search
but as your fairly new here, here's a thread to get you started,
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=21016
and this will help,
http://www.pocketgpsworld.com/tomtom-go-poi-alerts.php
You'll have to download the " data.chk" file for the sounds to work.
all explained in above thread.
Using an A to Z
Sextant & Compass
matt748
PostPosted: Wed Jun 08, 2005 5:27 pm    Post subject: Reply with quote
Hampie,
I'm a beginner myself, but your problem may be the same as I had. (If I'm wrong in this advice, I apologise. I'm sure someone will correct me)
When you copy the ov2 (speed cameras) folder onto the SD card as a folder, the contents won't show up on your TT. The folder has to be opened first, then 'select all' the files and copy them onto the SD card. Then they should work on the TT.
Matt
PostPosted: Wed Jun 08, 2005 6:30 pm    Post subject: Reply with quote
The OV2 file themselves have to go into the Map Folder. If you Copy/Paste the folder itself, TTG can only see the folder not the files.
HAMPIE
PostPosted: Fri Jun 10, 2005 8:51 am    Post subject: TomTom GO Reply with quote
matt748 wrote:
Hampie,
Matt
:D That works great- as you said, I needed to open the folder first and copy the appropriate files and not the folder itself.
Many thanks Mat - at last my hours of trying are over!
Hampie
