redbeard Occasional Visitor
Posted: Tue Jun 07, 2005 5:09 am Post subject: Garmin GPS V |
Couldn't find a review on this unit. I know a guy who is selling one for $100 with the software and mounting hardware.
Is it worthwhile, or would I be better off spending a little more and getting a system that works with my PDA? |
Posted: Tue Jun 07, 2005 5:23 pm Post subject: Garmin GPS V |
I forgot to mention that I live in the US and would primarily want to be able to do in-car address-to-address navigation.
Thanks. |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Tue Jun 07, 2005 6:03 pm Post subject: |
Hmm, you can connect the GPS-V to your PDA if you can find the right cable. Set the output to NMEA and it should work with just about any application that needs a GPS. You could end up with a lot of wires though.
The memory capacity of the GPS-V isn't much these days, I got the Greater London maps, plus a bit more on mine (population of the area about 12 million). Map uploads are slow - about 45 minutes over a serial cable.
It does turn-by-turn autorouting and can calculate routes. It makes clever use of the fairly small screen and the directions are usually fairly good.
You can create routes on the PC using the included Mapsource program and upload them to the GPS. Mapsource also manages the waypoints, tracks, maps etc.
The processor is fairly slow, it can be slow to calculate a route, a minute or more is not uncommon. If you are moving, it takes even longer to calculate. Screen redraw can take 5 or 10 seconds sometimes.
It runs for about 12 hours on 4 AA batteries.
I've had a lot of fun with mine on the road, trail, water or in the air. It's robust and water proof, real quality construction. Mine is barely marked after a few years of use and a few knocks.
For such a small unit, it is loaded with features - I was finding new ones after having the GPS for a couple of months!
$100 is pretty cheap, the GPS-V is a good little unit although it's getting old now. I loved my one, but I now have a Garmin Quest. _________________ Gone fishing! |
Posted: Tue Jun 07, 2005 6:14 pm Post subject: Garmin GPS V |
Thanks for the info. However, it sounds like I might be better off spending a little more money and getting something that is specifically designed to work with my PDA. I've found a couple of recievers that come with cables specifically designed for my PDA, mounting hardware, and mapping software that run about $200. That sounds like it might be a better investment.
Thanks again. |
Posted: Tue Jun 07, 2005 6:25 pm Post subject: Re: Garmin GPS V |
Definately consider getting a Bluetooth GPS if your PDA supports it.
BT can be a bit of a hassle to setup but I much prefer wire free to wired setups. _________________ Gone fishing! |
Posted: Wed Jun 08, 2005 4:03 am Post subject: Re: Garmin GPS V |
Skippy wrote: | Definately consider getting a Bluetooth GPS if your PDA supports it.
BT can be a bit of a hassle to setup but I much prefer wire free to wired setups. |
Thanks. Sadly, my PDA doesn't support Bluetooth. But I have found a kit designed for my PDA that includes a receiver, mapping software, air vent mounting hardware, and a power cable that handles both the PDA and the receiver connection for about $200. So far it looks like the best choice - though I'm going to do a little more research before buying anything.
One option that I haven't explored is getting a BT unit coupled with an add-on BT option for the PDA. That is one of the things that I still want to research. |
Posted: Wed Jun 08, 2005 1:50 pm Post subject: Re: Garmin GPS V |
redbeard wrote: | One option that I haven't explored is getting a BT unit coupled with an add-on BT option for the PDA. That is one of the things that I still want to research. |
Conversely, you might consider finding a BT gps which will also do a serial cable output if you want to upgrade your PDA to a BT enabled one in the near future.
If you are keeping your PDA for a while then you can probably save money and get a wired GPS a lot cheaper than a BT one and then buy the latest and greatest BT GPS when/if you eventually upgrade your PDA in a few years time.
Sorry that I can't recommed any specific GPS units, there are hundreds out there. Good luck finding the best one for your needs!! _________________ Gone fishing! |
