Pocket GPS World :: View topic - Emtac CruxII BTGPS - Questions and queries
macJasp
PostPosted: Thu Mar 24, 2005 2:57 pm    Post subject: Emtac CruxII BTGPS - Questions and queries Reply with quote
Hi all
I have this device, couldn't get it working with tomtom on my smartphone but then used CruxView and changed from SiRF to NMEA - now all is great - however!.... I switched it off and left it for a few days, tried again and it wouldn't work. I'd noticed it had gone back to SiRF mode
questions i have (hopefully you guys can answer a few of them)
1) Does it reset to SiRF after a few days without use?
2) Does a reset using CruxView reset the device to factory defaults?
3) Can i have the default on reset to be NMEA and not SiRF?
Hope you can help, i'm off to london next week and was need this working otherwise i will definitely get lost! But i don't have any smartphone software to change from SiRF to NMEA incase of disaster while i'm away?
Help appreciated as always!
SpeedCam
PostPosted: Mon Jun 06, 2005 10:00 pm    Post subject: Reply with quote
I have the same problem, if its the same as mine it was supplied as part of the Kane GPS system, Kane supplied EMTAC units that defaulted to Sirf mode.
exwrexona
PostPosted: Thu Jun 30, 2005 11:51 pm    Post subject: Emtac Crux II change default from SiRF to NMEA Reply with quote
I am having exactly the same problem with TTN 5 on my iMate JAM and yes my EMtac was originally bundles with Kane. Has anyone found a solution to permanently changing the default startup mode to NMEA rather than SiRF?
Workaround so far is to use either GPSTweak or CruxView to change it over before I launch TomTom Navigato 5.
Any help would be appreciated.
Regards
22.064 (26 Jun 24)
