Pocket GPS World :: View topic - BT 16 Channel - 20 hour
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
iancjc
PostPosted: Tue May 24, 2005 2:01 pm    Post subject: Reply with quote
have you paired the device through bluetooth manager and set up a serial port profile?
Ian
TTN6.03 tomtom 7.xx (one)
adamforman
PostPosted: Tue May 24, 2005 2:08 pm    Post subject: Paired Reply with quote
I have paired the unit successfully
When i check the status it shows conncected
and when i select active connections and view the outgoing conncections it shows SPP Slave
any suggestions ?
iancjc
PostPosted: Tue May 24, 2005 2:21 pm    Post subject: Reply with quote
in tomtom gps screen - GPS tab
select NMEA 0183v2 9600
select Bluetooth serial port com ???
??? being the number of the incoming bt serial port - if you are unsure which is which try both until;.
on the STATUS tab
you see dots running from sat icon to pda icon
then you should see the red bars on the tomtom display.
HTH
Ian
adamforman
PostPosted: Tue May 24, 2005 2:37 pm    Post subject: madness Reply with quote
I haves spend the last few hours doing exactly what you said... even beofre i made a post !!! to this forum.. its all working no idea what i did differently !!!
iancjc
PostPosted: Tue May 24, 2005 2:43 pm    Post subject: Reply with quote
great news!
glad its working now Laughing
Ian
adamforman
PostPosted: Tue May 24, 2005 5:52 pm    Post subject: ARGGHH Reply with quote
Thanks for your help on this, I have the little dots running across from the sat to the handheld on the tomtom gps and the time is displaying, how long does it normally take for all the data to take in to effect and display details like N & E and MPH???
any help would be appreciated
iancjc
PostPosted: Tue May 24, 2005 6:33 pm    Post subject: Reply with quote
do you have a clear view of the sky?
The first time you use it it can take half an hour to download the info as the sats come into view - after this it should be less than a minute.
I would leave it outside away from building etc for 15 + minutes and you should get a fix.
Are there any grey bars showing - these will turn red when a fix is made?
Ian
adamforman
PostPosted: Tue May 24, 2005 7:20 pm    Post subject: Thanks Reply with quote
Ahh I understand now, i wish there was a proper manual with this unit, its on a PDF but nothing tells you about this.
I have a few grey bars and Im in a flat at the moment, I will take this with me tonight and leave it on to see if it works
Thanks for all your help
adamforman
PostPosted: Wed May 25, 2005 11:02 am    Post subject: this is fun... Reply with quote
ok so now I have read all the posts all over the net, I have upgraded the tomtom gps componet this has changed the icon , it seems to work better . I have also installed the app : VisualGPSce which shows me what sats are in view and helps tons. I did try and install the latest TOMTOM GPS that you can download from this site BUT after installation it asks me to install a proper version of tomtom and cant find maps... so i have taken it back to GPS version 3.07 rather than Version 4. any news on the newer version of GPS out there that works on all pocket pcs !
iancjc
PostPosted: Wed May 25, 2005 1:50 pm    Post subject: Reply with quote
version 3.07 is the latest version that works on all pocketpc's!
stick with it until ttn5 comes out - which will come with a revised gps section.
tex
PostPosted: Sun Jun 05, 2005 5:48 pm    Post subject: Reply with quote
I rcvd this receiver the other day. It has worked a total of two times for me. My current problem is that I get the flashing red light (sat lock) and I have it successfully paired to my laptop, despite these two facts, I don't show any data crossing the line. I've tried numerous programs (terminal, visualgps, visualgpsxp) to try to see the data, but no luck. MS Autoroute 2005 says it can see the port, but that there's no gps data. Does anyone out there have any clues?
Dell Inspiron 700m
Hama usb Bluetooth Adapter (class 1)
GPT-600 Bluetooth Receiver (repackaged BT77)
n7610
PostPosted: Wed Jun 08, 2005 7:41 pm    Post subject: Nokia 7610 and Bt 77 Reply with quote
ianrickycarmichael wrote:
i am having the same problem as brandi. have paired a bt 77 with nokia 7610 succesfully and am using tom tom mobile software. tom tom is saying its waiting for a valid gps signal and gps device is displaying a steady flashing red light on left and a steady flashing blue light on right -every 3 secs.could it be sonmething to do with installing the drivers to the phone incorrectly or is it something else-help please.
ianrickycarmichael, do you manage to get it work?
gshaw
PostPosted: Mon Jun 13, 2005 9:39 pm    Post subject: Reply with quote
So are these 2 the same device just a different case?
I really don't know what to do - it seems a risk with these but I can't afford like 150 quid from a shop - would ppl recomend these to use with Route 66 and Nokia 7610??
Cheers,
Gerrard
111hhh111
PostPosted: Sat Jun 18, 2005 1:26 pm    Post subject: Reply with quote
Sorry if this has been asked before, but does anyone know of a replacement battery for the Unit. I think mines on the blink. Thanks in advance.
Spark1e
Banned
PostPosted: Sat Jun 18, 2005 2:04 pm    Post subject: Reply with quote
If you've got the BT-77 (the 2nd picture above) then a Nokia 6230 battery will fit. Don't know about the other one sorry, but they do look the same ??
Page 6 of 9
