Pocket GPS World :: View topic - O2XDA2s BT Headsets connection problems
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion
PostPosted: Sun Jun 05, 2005 12:55 pm    Post subject: O2XDA2s BT Headsets connection problems Reply with quote
I have just purchased an O2XDA2s, the Bluetooth works fine with the GPS and TT3, it will also "pair" with my headset (I have tried 3 different ones all with the same result) when I select connect to headset the XDA states "Connection Failed" - any thoughts as the O2 shop and tech assistance via phone unable to fix - there is a ROM upgrade avail which I will try, any ideas greatfully received - Mike
alix776
PostPosted: Sun Jun 05, 2005 1:14 pm    Post subject: Reply with quote
the rom up grade should fix the issue
device Lumia 950 xl
PostPosted: Sun Jun 05, 2005 7:42 pm    Post subject: Reply with quote
Thanks for the quick reply - I have installed the upgradded ROM and the headset works fine - I then re-installed all the software (incl TT3) and the headset failed to work - hard reset and the headset works so it must be the TT3 that is causing the problem - I have read on this forum before that it can "hijack" the BT port any sugestions would be most welcome - as I don't want to go back to seperate PDA and phone - Mike
alix776
PostPosted: Sun Jun 05, 2005 7:49 pm    Post subject: Reply with quote
try down gradeing the gps driver to 2.06 tt3 shouldnt really affect the headset as they use diffent profiles try installing pocket bluetooth tools
http://www.bluetooth.jazztel.es/
device Lumia 950 xl
PostPosted: Mon Jun 06, 2005 7:06 am    Post subject: Reply with quote
I installed the bluetooth tool set you mentioned and that to locked out the headset in the same way the TT3 did, I have not yet found the earlier vs of GPS driver but will have a look tnight when back from work - cheers - Mike
PostPosted: Fri Jun 24, 2005 7:19 pm    Post subject: Reply with quote
just loaded tt5 and the headset now works and will connect fine, the gps via bluetooth isn't working but thats down to settings - thanks XDA for the pm's will get there in the end - only taken 4 weeks of pratting about but i can finally see the light at the end of a frustrating tunnel - cheers all mike
PostPosted: Sat Jun 25, 2005 9:43 am    Post subject: Reply with quote
OK got the TT5 loaded up and working, also got the GPS to connect at the same time - its a bluetooth unit but will only will only appear to work if I select the "other wired receiver", correct baud rate to 9600 then select bluetooth port from the list of choises offered. I find the GPS set-up in TT5 more restrictive than the previous but its probably unfamiliarity. Things were looking up until I made a call with TT5 running - all works great until you terminate the call with the bluetooth headset, it disconnects the GPS - useless for driving, So back to the wired GPS receiver which should arive early next week. One other query relative to the XDAII, if entering a postcode how do you get the on screen keyboard to pop up mine willonly allow data entry though the slide out keyboard - not an option in the car holder! and secondly when I get the wired GPS I will have disable the inbuilt keyboard, to use the serial port - anyone any thoughts - Best Regards - Mike
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion All times are GMT + 1 Hour
22.063 (19 Jun 24)
