Pocket GPS World :: View topic - Running a Simulation
Bazzer
PostPosted: Wed Jun 01, 2005 8:43 am    Post subject: Running a Simulation Reply with quote
I'm running CP5 on my Mio168. After all of the well documented problems and Dave B's request for details of issues that users have, I want to run some simulations on my PPC in areas where I have encountered anomalies (which are numerous), before emailing the results to Dave B.
However, while I can plan a journey in an area in question, is it possible to run the journey as a simulation which gives full voice commands, as you would expect on a live trip ? I can't work out if this can be done.
Your help would be appreciated.
Baz
lbendlin
PostPosted: Wed Jun 01, 2005 1:15 pm    Post subject: Reply with quote
I don't recall if CoPilot has this feature, but you can always use GPSGate to replay NMEA logs, and then point the navigation programs at the GPSGate COM port.
Lutz
TomTom/TeleAtlas NAVTEQ
Bazzer
PostPosted: Wed Jun 01, 2005 3:09 pm    Post subject: Reply with quote
While I may be a fairly competent user, and by no means a technophobe, I'm afraid I haven't got a clue what Lbendlin is talking about Confused
While it may appear that I cannot achieve what I want directly on PPC by creating a route and running it as a simulation (please correct me if I'm wrong), can I utilise the GPS track for a similar purpose.
However, I do not want to sit through 200 miles of uneventful motorway waiting for something to happen. Can I just play part of the track, or crop a section from it to be played back ??
Thanks for your help
Baz
PostPosted: Sat Jun 04, 2005 7:07 pm    Post subject: Reply with quote
What you can do is under the GPS option is to open an existing track. If you knew you took a journey from home to work on a specific day and wanted to re-plot the route and demo it, you can OPEN GPS TRACK, then PLAYBACK GPS TRACK, set the desired speed, and then create the journey as you would by starting a new journey. It then reads this rather than the GPS COM port and allows you to effectively re-drive a route.
22.054 (22 May 24)
