Pocket GPS World :: View topic - Etrex and USB Connection. Help Please
AAH
PostPosted: Mon May 23, 2005 11:54 pm    Post subject: Etrex and USB Connection. Help Please Reply with quote
I have an etrex and a serial port lead. I have got a usb to serial lead and can now connect this to my dell inspiron 9100. However, using Mapsourse, the etrex is not reconised. Can anyone help wit this please? The notebook does not have a serial port
Pc-Mobile
PostPosted: Tue May 24, 2005 7:21 am    Post subject: Reply with quote
Is it because Mapsource only recognise com1-4 and your USB>serial converter is assigned a com port greter than 4?
If so try to change the com port number.
I am wondering whether a newer version of Mapsource will recognise a com port greater than 4.
Pc-Mobile
http://pc-mobile.net/gps.htm
AllyCat
PostPosted: Tue May 24, 2005 1:08 pm    Post subject: Reply with quote
Free upgrades to Mapsource are available from the Garmin website. I'm running v6.5, which has 8 COM ports listed on the GPS tab. The "transfer" menu now seems to do an automatic search, which might find even more!
Cheers, Alan.
Garmin GPS72H/76/60/45, Etrex H, Mapsource v6.5.
Acer N50,HP114,Loox N560,Dell x50,CF/SD cards to 4/32GB.
RoyalTek,Holux236,Navman B10 & Copilot(Globalsat) BT GPS,TomTom5/6.
Memory Map (v5.4.2 & v5.1.3 OS & Euro), GPS gate,OSGPSconverter.
AAH
PostPosted: Tue May 24, 2005 10:37 pm    Post subject: Reply with quote
I also want to use DNR garmin to upload waypoint from walkingworld.com. I have found the usb to serial in device manager and it has con 15 in brackets after it. The software that came with the usb to serial lead does not indicate who made it and does not install with the add new hardware wizard. How can I change a com port to a number bet 1-8? the ports are all bluetooth enabled??
AAH
PostPosted: Wed May 25, 2005 7:26 am    Post subject: Reply with quote
The usb to serial lead is in the HID section of device manager and has the drivers installed. The mapsourse update fron garmin has failed to 'find' it. It remains in com 15?? Any ideas please??
Pc-Mobile
PostPosted: Wed May 25, 2005 11:03 am    Post subject: Reply with quote
What OS?
You have to change the assigned com port smaller than 8.
It is simple if you know how. It can be complicated if you do not.
I cannot help you here but may be someone else will.
Or look at MS knowledge base.
Pc-Mobile
22.055 (29 May 24)
