iancjc Frequent Visitor
Joined: 10/02/2003 14:19:44 Posts: 749 Location: United Kingdom
Posted: Sun May 22, 2005 5:27 pm Post subject: |
Can't help on the cd problem - sounds like it's faulty - when I purchased the kirrio kit the cd that came with it was cracked, globalpositioning systems swopped the cd without a problem - but I had to send the whole kit back.
Looking at the website - although the software is comptabile with the T5 the kirrio kit isn't - if you purchased the BT gps set then you can just buy a different mount (either powered or not - if not buy a seperate car charger).
If you got the wired version then I would return the whole lot for a refund as kirrio are unlikely to have the correct connector available quickly. GPS.co.uk are very good for refunds/returns , just make sure you get an rma no. before returning the kit. You would be better off buying the viamichelin software direct from michelin's web site and getting a seperate mount and bt gps unit - or buying the complete t5 compatible kit from viamichelin.
The download to v3 won't work either until you have installed the original software from the cd onto your pc.
Ian _________________ -----------------------------------------------------------
TyTn II (WM6.1) / tomtom one v2
TTN6.03 tomtom 7.xx (one) |
NeedGuidance Occasional Visitor
Posted: Sun May 22, 2005 10:25 pm Post subject: |
Ian,
Many thanks for getting back to me.
After trying out a few things last night - including copying the CD Rom to another CD, I eventually got the original CD to load - but after spinning for a good 30 minutes. I had to do this several times, as the early tries did not make it through to completion.
I eventually managed to install v2.5 onto my PC, then proceeded to download v3. For some reason, the v3 installation aborted due to lack of memory.
As for the GPS unit, I got the bluetooth version and it worked with my T5 under Naviation v2.5. Took it for a test run today to Cambridge and it worked like a dream. I will get a car charger for the T5 instead as it is probably the best solution to this problem.
Next step for me is to figure out how I could load v3 onto my T5 successfully. Perhaps I could remove The Michelin Guide for Europe first.
By the way, did your come with The UK & Ireland Michelin Guide 2004?
Chris |
Posted: Sun May 22, 2005 11:09 pm Post subject: |
No michelin guides came with the box.
You may want to download the v3 file again - the first time I downloaded it wouldn't install, I downloaded it a second time and it was ok.
g7pkf Occasional Visitor
Posted: Thu Jul 07, 2005 4:10 pm Post subject: Nightmare downloading |
Cant figure whats wrong tried downloading about 5 times the update now.
can someone please email me a good copy of the free upgrade 2.5-3?
dean AT packetradio DOT co DOT uk
thanks |
old_lou Occasional Visitor
Posted: Fri Aug 05, 2005 12:48 pm Post subject: Re: Nightmare downloading |
g7pkf wrote: | Cant figure whats wrong tried downloading about 5 times the update now.
thanks |
Are yo sure you want an 18meg file emailed to you? |
