jkeepi Occasional Visitor
Posted: Sat May 21, 2005 6:28 pm Post subject: TomTom Nav 3 - Can't Find Maps |
I had TomTom navigator 3 working fine on my Pocket PC, until I let the battery run down. I then had to install the software onto my Pocket PC again. However, when I tryed to run the software it said it couldn't find a map, although it is sitting there on my CF.
I decided to do a hard reset on my Pocket PC and clear any trace of the TomTom install files on my desktop PC. I then did a fresh install of the TomTom navigator and the GB map but I'm still having the same problem.
Does anyone have any ideas as this is drivinf me nuts!!! |
lbendlin Pocket GPS Staff
Posted: Sat May 21, 2005 9:29 pm Post subject: |
which version of TomTom did you install after the hard reset? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sat May 21, 2005 10:08 pm Post subject: |
It was version 3 which is exactly the same version as the previous install. |
Posted: Sat May 21, 2005 10:39 pm Post subject: |
is it 3.01 or 3.03 or 3.07 ? _________________ Lutz
Posted: Sat May 21, 2005 10:59 pm Post subject: |
Oh right... sorry see what you mean.
I've got just plain 3.00 on there but have also tryed 3.03 to no avail. |
Posted: Sat May 21, 2005 11:04 pm Post subject: |
Try to upgrade to 3.07. Let me know if that helped. You may also want to delete the CFG file, just in case. This will reset all settings. _________________ Lutz
Posted: Sat May 21, 2005 11:55 pm Post subject: |
Ok, just tryed the 3.07 update and I can now run the Navigator. However, I can't run the wizard to setup the connection with my bluetooth GPS receiver! When I run the wizard I get the same error about not being able to find the maps.
Is there an update perhaps to the wizard too?
Is there a simple way to manually connect to the tomtom bluetooth GPS device?
Thanks for your help. |
Posted: Sun May 22, 2005 12:06 am Post subject: |
I found out how to manually set the GPS device so I've got it all working fine now. I am still a bit miffed as to why I've had to jump though hoops to get this working when originally I had no problems at all.
Is the problem I have faced a common thing?
Thanks foyyour help lbendin |
Posted: Sun May 22, 2005 12:21 am Post subject: |
Using the Wizard, and using TomTom GPS 3.03 are the most common issues. The way you have done it - to manually set the receiver - is still the best option. _________________ Lutz
