Pocket GPS World :: View topic - HP6315 and GPS Reciever
shere
PostPosted: Sat May 21, 2005 8:33 am    Post subject: HP6315 and GPS Reciever Reply with quote
Hi, I bought a HP 6315 Ipaq. Its the best pda by far. I then bought a Globalsat BT-338 bluetooth reciever. I can pair the two devices sucessfully but when I go to use my Tom Tom it doest work. The gps s/w doest recognise the settings. I've tried all the com ports etc. I've also unticked the beam in Syetm\Properties.
What settings should I use? any ideas where I go from here? The bluettoth device is definitely connected and it works.
Any response would be grateful
PostPosted: Sat May 21, 2005 2:26 pm    Post subject: Reply with quote
It works perfectly with the standard settings. COM7 on NMEA 38400. Don't forget to connect to the SPP service of the receiver first.
shere
PostPosted: Sat May 21, 2005 2:35 pm    Post subject: Reply with quote
hi, thanks. HOw do I connect to the spp service?
shere
PostPosted: Sat May 21, 2005 2:41 pm    Post subject: Reply with quote
Hi, I dont have com 7 listed for that type. I have that type in the drop down box on tom tom but not the com ort.
alix776
PostPosted: Sat May 21, 2005 2:47 pm    Post subject: Reply with quote
select it in the drop down box and it should work also make sure the ir reeive all oimcoming beams is turned off
with tt if yoir useing 3.07 in the com port selection box try selecting bluetooth gps and see if that works
device Lumia 950 xl
shere
PostPosted: Sat May 21, 2005 3:02 pm    Post subject: Reply with quote
Hi, how do I know which version of tom tom im using?
when im in the gps screen, which settings in the two boxes should I be using. If I select the settings and then tick the box should it work? or should I retsrat the bluetooth connection?
This is driving me crazy
PostPosted: Sat May 21, 2005 3:41 pm    Post subject: Reply with quote
Start >Programs > iPAQ Wireless > BluetoothManager
tap and hold the "BTGPS etc" device, then tap "Connect"
Start >Settings > System > GPS > GPS
Top dropdown: NMEA Standard 38400
second dropdown: Bluetooth serial COM7:
Check the tickbox
go to the status tab and see if the black dots are running.
At the bottom of the status tab is the GPS driver version.
shere
PostPosted: Sat May 21, 2005 4:01 pm    Post subject: Reply with quote
I have paired the blutooth. This is connected and showing
BT - GPS-303EEC and also BT-GPS COM Port.
When I go to gps\gps. I select NMEA 0183V2 38400. The drop down box is showing Bluetooth Serial Port Com 4 and not COM 7.
Version is V3.00 402/400.
Still not working, any ideas?
PostPosted: Sat May 21, 2005 4:03 pm    Post subject: Reply with quote
uninstall the TomTom GPS driver (twice) and reinstall TomTom GPS 2.06
shere
PostPosted: Sat May 21, 2005 4:07 pm    Post subject: Reply with quote
Where do I get the gps driver from? is it best to update the tom tom to version 3.07?
thanks
alix776
PostPosted: Sat May 21, 2005 5:40 pm    Post subject: Reply with quote
2.06 can be hd from the downloads section of this site as can the cab file for 3.07 as your running wm2003se then id got to 3.07 and gps 2.06 copy them to directly to the ipaq using active sync and then using file explorer find and tap them cab files to execute them
device Lumia 950 xl
shere
PostPosted: Sat May 21, 2005 10:48 pm    Post subject: Reply with quote
Hi, I upgarded to 3.07 and now I can see the com port 7. This is now working fine.
It did take me most part of the day. Result!!!! Thanks for your help. :D
22.071 (03 Jul 24)
