Pocket GPS World :: View topic - Destinator 3 Database Errors
PostPosted: Sun Nov 30, 2003 1:21 pm    Post subject: Destinator 3 Database Errors Reply with quote
Please post any database errors you find in searching for towns/roads etc in this thread.
RickJ
PostPosted: Fri Dec 19, 2003 8:33 am    Post subject: Reply with quote
Tumwater, WA is not in the Address index. Crying or Very sad I was told by a PowerLoc technician that I would have to use the zip code instead of the City name to input addresses in Tumwater. This worked but concerns me, as you generally don't use zip codes (who knows many of them) to locate cities, i.e., you know Cities by their names, not their zip codes.
BTW, Tumwater was in the Address index of Destinator2.
typhoon29
PostPosted: Sun Mar 21, 2004 6:36 pm    Post subject: Reply with quote
Received Destinator 3.0.54 yesterday, there's a couple of bugs I've noticed.
1) The verbal instruction to take exit 4 at a roundabout is missing, It say something like " Take roundabout Exit" then it just bleeps, omitting the spoken word 4.
2) Instead of giving the audible warning of roundabout 2 miles, it mistakenly says " Take roundabout 3 miles"
stoneman
PostPosted: Wed Mar 23, 2005 11:42 pm    Post subject: Reply with quote
Not so much errors, more if you dont have the postcode of your intended destination looking up can be extremely difficult.
The town lookup dosent really work it seems to be you need to look for the borough rather than the town eg:
Tooting comes under the borough of Wandsworth
Plough lane Wimbledon comes under sutton
Verdant lane Hither green comes under london
eastworth road chertsey comes under runnymede
etc. etc. this all being very well if you happen to know the borough you are going to.
Just something to be aware of.
Regards
Stoneman
ReZ
PostPosted: Thu May 19, 2005 9:20 pm    Post subject: Reply with quote
a full 6 digit postcode would sort it all out but i guess too much ram ?
ie >postcode >house number
why does it think the a5 is better heading into london than the a41 ? :P
/ReZ
ReZ
PostPosted: Thu May 19, 2005 9:21 pm    Post subject: Reply with quote
and yeah stoneman i get that a lot with the borough thing.... pain
marksfish
PostPosted: Mon Jul 04, 2005 6:51 pm    Post subject: Reply with quote
And the bug hasn't been fixed in 3.0.75 either :x Is there a wrok around available that anyone can le me know please?
Mark
AllyCat
PostPosted: Tue Jul 05, 2005 7:51 pm    Post subject: Reply with quote
Hi Mark,
Yes, the "3 miles" voice error can be corrected to 2 miles simply by editing the "DestinatorVoiceManeuvres.inf" file, using say Notepad. It can be found on the PPC in:
DestinatorApps/Destinator/Common/Interface/Voice/All
Change the "3" to "3*2" in the appropriate roundabout intruction line (compare it with the turn commands). i.e. change it to:
::MC,ROUND_ABOUT*FIRST_DISTANCE,0,0,circle;EXIT_NUMBER;exit;3*2;UNITS,"Take round about xxxx exit 3/2 miles/kilometers"
You can make many other changes to the voice commands if you wish, e.g. see my post in the following thread:
http://pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=21290&start=15
Cheers, Alan.
Garmin GPS72H/76/60/45, Etrex H, Mapsource v6.5.
Acer N50,HP114,Loox N560,Dell x50,CF/SD cards to 4/32GB.
RoyalTek,Holux236,Navman B10 & Copilot(Globalsat) BT GPS,TomTom5/6.
Memory Map (v5.4.2 & v5.1.3 OS & Euro), GPS gate,OSGPSconverter.
marksfish
PostPosted: Thu Jul 07, 2005 8:44 pm    Post subject: Reply with quote
Thanks for that Alan, i'll give it a go.
Mark
gune
PostPosted: Sat Oct 29, 2005 11:45 pm    Post subject: destinator in dorset and london Reply with quote
hi all:
using d3 down the road to dorchester on A35 suddenly it says turn left. though initailly it says 3 to 6 miles away the next turn.
this a glitch! a wrong route, ironically if u turn it will say make u turn.. which is correct!! but no funny!
also i found d3 without london congestion markings is a pain in the bum!
i found many times d3 cuts across london city!
even if i put the settings at fastest not shortest.
it also has the ability to take u thru most obscure roads in london.
last it took me to a ferry port at woolwich instead of taking the blackwall tunell. unfortunately ferry port was closed!! not very helpful.
finally it took me 3 1/2 hrs to get to east london from west london.
but next day it took me to hillingdon with out any hitch. i usually now days check rac route planner as well.
this time alone d3 was superior to rac route planner. also return trip via m3 it calculated fine.
but this is out moe than 10 badly calculated routes!!!
it also somtimes say turn left but route on display is to right!!
gune
PostPosted: Sat Oct 29, 2005 11:47 pm    Post subject: Reply with quote
addendum
d3 has the definite abilty to take u thru forests or roads going acroos forests than main roads....
grantson
PostPosted: Tue Dec 27, 2005 8:49 pm    Post subject: Reply with quote
Rait road in perth is an unknown road
new scone filling station no longer exists & the balbeggie services which has been there for years is not mentioned
also the wellgate carpark in dundee has been renamed to the wekkgate by whever set up the database
22.063 (19 Jun 24)
