Pocket GPS World :: View topic - Globalsat 2 pin plug
tigermad
PostPosted: Sat May 14, 2005 9:05 am    Post subject: Globalsat 2 pin plug Reply with quote
I have just bought a Globasat bluetooth gps off ebay. The unit will come with a large 2 pin plug. I can only seem to find small round adapters so I can convert it to a 3 pin plug. Can anyone suggest somewhere I can try?
TIA
PostPosted: Sat May 14, 2005 9:38 am    Post subject: Reply with quote
You'd be better using the correct adapter. UK wiring regs require a specific 3 pin plug for cable that is 2-core (i.e. lacks earth) and these special plugs have a plastic middle pin.
Find out what plug type it is and confirm that it is 220/240v or 220/110v first. If it's 110v only then you'll need a trsnsformer and cannot connect it deirectly to 220/240v supplies.
It will most likely be a standard Euro 2 pin plug, the converters for these are inexpensive and easy to source.
Steve999
PostPosted: Sat May 14, 2005 12:28 pm    Post subject: Reply with quote
Hi there,
If your Globalsat is US or Canada sourced, it will have a power pack with two transverse pins designed to fit North America mains sockets. Mine is a Touch Electronics type SA0105-A which auto detects voltages from 100 to 240 volts and works either way round polarity wise. It came from Canada and I have been using it for about a year now with my BT-308. All the important info should be on the charger itself if it came from North America.
If yours is of this type, then it will work fine plugged into a common or garden UK shaver adaptor that can be obtained commonly for about £1.50.
PM me if you have any further query.
Steve
Google Pixel 4a 5G Handset
Sygic
CoPilot
Nissan Connect
tigermad
PostPosted: Sat May 14, 2005 2:42 pm    Post subject: Reply with quote
Thanks for the replies. It will take about a week before I get it so I will post what adaptor it is then. The plug looks like a rectangular block in the picture but I do not know if its european or american yet.
tigermad
PostPosted: Sat May 14, 2005 2:47 pm    Post subject: Reply with quote
Thats weird the image didnt work Sad[/img]
PostPosted: Sat May 14, 2005 4:32 pm    Post subject: Reply with quote
You had the image tags the wrong way around.
That's a US adapter as detailed by Steve999. It should be 220/110v auto switcheable so you can use an adapter. You MUST not replace it with a UK plug.
Steve999
PostPosted: Sat May 14, 2005 6:55 pm    Post subject: Reply with quote
That appears to be the identical charger to the one I have and described above.
If so, simply buy a UK 3 pin shaver adaptor from Woolies or similar - fits perfectly.
Steve
Sygic
CoPilot
Nissan Connect
tigermad
PostPosted: Sat May 14, 2005 7:00 pm    Post subject: Reply with quote
Thanks guys. Can't wait to get it now. Hope its as good as I have reading on here! Smile
tigermad
PostPosted: Sat May 14, 2005 10:09 pm    Post subject: Reply with quote
Sad I have just noticed. In the picture the unit seems to have 3 green LEDS. Surely they should be different colours according to others I have seen?
Steve999
PostPosted: Sun May 15, 2005 9:21 am    Post subject: Reply with quote
Calm down! It's only a commercial. Photo reproduction can be deceiving.
My Globalsat, although a different model, came from Canada and apart from the charger pins already discussed, is identical in every way to one you would buy anywhere else.
Steve
Sygic
CoPilot
Nissan Connect
tigermad
PostPosted: Thu May 19, 2005 7:47 am    Post subject: Reply with quote
Well the bt-338 arrived an what a beauty it is!
Just one more quick question about power.
Can I just use a multi voltage adaptor to charge it and not use the 2 pin at all?
I have recently bought one that is switchable and comes with 7 different ends to power my pda tv card.
I thought I had better ask in case I blow the thing up Rolling Eyes
PostPosted: Thu May 19, 2005 7:56 am    Post subject: Reply with quote
That depends on if you trust it! I'd just buy the adapter and use the supplied power unit.
22.094 (25 Sep 24)
