fergusd Occasional Visitor
Posted: Thu May 19, 2005 12:06 am Post subject: 204E VTG enable via nmea ? |
I've been trying to enable VTG sentance generation on a 204E, using $PSRF1003......, but this doesn't work . . . so . . . how can I enable and disable sentance generation . . . possible using nmea ?
Fd |
lbendlin Pocket GPS Staff
![](http://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Thu May 19, 2005 12:25 am Post subject: |
This may well be an Evermore chipset. What does it report when you open the connection? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Thu May 19, 2005 12:29 am Post subject: |
When I open the com port ?
Seems to run all the time (in that the nmea stream runs all the time), or am I not understanding you ?
It's a mini-din unit with a USB adapter . . . although I'd have though that would make no difference . . .
I've tried this using good old hyperterminal, and GPSDiag . . . both results are the same, no change to the output stream . . .
Fd |
Posted: Thu May 19, 2005 12:47 am Post subject: |
I meant open the COM port with your own software. If you use the standard software then you miss the exciting part - at the beginning of the transmission it tells you about chipset etc. _________________ Lutz
Posted: Thu May 19, 2005 12:52 am Post subject: |
Only line out of the ordinary on power up is . . .
$PLCS,REV,PCT011016S01,040709,105853
Fd |
