Pocket GPS World :: View topic - Mio 168 antenna positioning
MattHirst
PostPosted: Wed May 18, 2005 1:38 pm    Post subject: Mio 168 antenna positioning Reply with quote
Quite a trivial question, since it seems to work both ways, but in which position are you MEANT to have the built in antenna, out at 90 degrees with the flat top pointing to the sky, or all the way up as far as it will go? I've seen pictures of it being used both ways round, and through testing it seems to work both ways, but which way are you MEANT to use it??
PostPosted: Wed May 18, 2005 4:31 pm    Post subject: Reply with quote
it's meant to be used with the antenna in horizontal position, but it's pretty sensitive and can be used flush to the case too without much difference in signal. Definitely no need to put it all the way up.
Loobster
PostPosted: Wed May 18, 2005 4:55 pm    Post subject: Reply with quote
I find mine works best (and starts up quickest) if I put it at about 30 degrees from horizontal.
--Loob.
22.064 (26 Jun 24)
