Pocket GPS World :: View topic - 3.03 but still BT lockups on 2210
Goto page Previous  1, 2, 3, 4
Talkingbollox
PostPosted: Wed Jul 21, 2004 6:42 pm    Post subject: Reply with quote
EvilHomer
That sounds like a BT receiver issue.
I say that because the GPS signals never drop if you use a serial mouse. If your theory is right then serial receivers would be affected?
rawman
PostPosted: Thu May 12, 2005 1:11 am    Post subject: freezes up after 20 mins on a Toshiba Reply with quote
i have the Toshiba E740 its the model without bluetooth built in so i have to use a belkin pda bluetooth compact flash model no: f8t006, i find that no matter what i have tried i still get freezes after about 20 mins and have to come out of the tom tom program and then reload it all works again but so annoying and dangerous when driving. and it allways cuts out at junction you dont know or worse. i have tried about 4 sd memory cards as that seem to be a issued at one time all makes of cards still report same problems so i dont believe it got anything to do with memory speeds or type of cards. have tried most of your suggestions to downgrading to a older versoin of gps but still it freezes up. just about given up with this all togather the only thing i can think of doing is to order a Toshiba bluetoth card on sd card slot or other make to try and see if using compact flash for the maps helps. another thing i have tried is to use mmc cards instead of sd cards. no diffrenece keeps crashing still. the only good thing i found out was the data could be written and read much faster. any other ideas please!!! im tearing my hair out over this i am very much upset that tom tom thenselves havent sorted this out still nearly a year since i have brought this. as on their box they say that its supposed to work with the toshiba e740
any help would be helpful thanks
Russell
PS please help me!!!!!!!!!!!!!!!
anybody out there
iancjc
PostPosted: Thu May 12, 2005 9:16 am    Post subject: Reply with quote
the problem is most likely caused by the bluetooth add on cards.
to be honest I wouldn't throw any more money at it in the form of bt sd cards I'd buy new hardware and ebay what you have.
sounds harsh but when you look at the price of a new dell/hp/acer etc pocketpcs and add the value of a years warrenty compared to the cost of another bt card it doesn't make sense.
The tosh is listed as compatible but is the bt card? You are adding an extra layer onto the spec of the tosh - are there any new drivers for the belkin unit?
The BT dropout experienced by users is/was very much restricted to the 2210/2215 ipaq and sd performance. My 2210 was fine until about 3 weeks ago when it started to do this as well - regardless of make / model of sd card - using cf for the maps made the problem go away. It is not TT fault it didn't work it was the ipaq and or the cards.
I've just upgraded to a dell x50v and the same sd cards and bt gps work fine together...
Sorry can't be of more(any) help
Ian
TyTn II (WM6.1) / tomtom one v2
TTN6.03 tomtom 7.xx (one)
rawman
PostPosted: Tue May 17, 2005 2:40 pm    Post subject: ok thanks Reply with quote
Ok Thanks Ian
will see what i can do about it if not im going to sell the old toshiba
Russell
biggy7
PostPosted: Thu May 19, 2005 10:24 pm    Post subject: Reply with quote
so what are we saying here is avoid the 2210 like the plague yeh?
has there been a fox for this in the past few months?
PostPosted: Fri May 20, 2005 7:33 am    Post subject: Reply with quote
Quite the opposite. The 2210 is/was possibly the best PDA available. The only caveat being to use CF Cards for Map storage if using a BT GPS. In every other respect it is superb and you can still use the SD slot for other data storage.
biggy7
PostPosted: Fri May 20, 2005 8:11 am    Post subject: Reply with quote
thnaks mate
so using the SD cards for maps would work fine then yeh?
biggy7
PostPosted: Fri May 20, 2005 8:27 am    Post subject: Reply with quote
ahh sorry read the post wrong.
so avoid SD and go with CF,
cheers
PostPosted: Fri May 20, 2005 8:49 am    Post subject: Reply with quote
That's right, with CF as the map storage medium the 2210 works perfectly. I use a 2210 as my test bed workhorse, still going strong after two years.
Page 4 of 4
22.062 (12 Jun 24)
