savo Occasional Visitor
Posted: Wed May 11, 2005 9:41 am Post subject: Help! I can't install the database on my TomTom Go 300 |
I have read the instructions on installing the speed camera database and it still doesn't work! Must be doing something wrong.
I copied the BMP and OV2 files into the great britain map folder (i copied the files from the ZIP folder by extracting them, do i have to unzip them first and then copy them?) and disconnected the Tom Tom from the computer and turned it on and nothing was there.
Whilst i was copying the files to the great britain map the Tom Tom screen had a little SD card symbol on there with an arrow and a cross through it, is that what should be displayed?
Any help would be greatly appreciated! |
michaelh85 Regular Visitor
![](modules/Forums/images/avatars/171685948942d6b3c282b7e.gif)
Posted: Sat May 14, 2005 8:39 pm Post subject: |
Have you told the tomtom to "show" the cameras in the "Manage POI" settings. You sound like you've installed them right but the TTG won't display them unless you tell it to in the manage POI settings |
Oldboy Pocket GPS Moderator
Posted: Sat May 14, 2005 10:54 pm Post subject: Re: Help! I can't install the database on my TomTom Go 300 |
savo wrote: | I have read the instructions on installing the speed camera database and it still doesn't work! Must be doing something wrong.
You have to unzip the file on PC first.
Next, copy over the .bmp and .ov2 files you want, into the map folder.
If you want the cameras to Warn When Near you must set up each one in turn. This will show the icons as you travel.
If you only want to see the icons in Browse Map you have to Enable in Manage POI's. They will also appear while travelling but will not warn unless setup as above. _________________ Richard
Posted: Tue May 17, 2005 8:42 am Post subject: |
Thanks Guys..I will give it a go! |
