Pocket GPS World :: View topic - Postcodes (did you think we would not notice?)
Wishlist
PostPosted: Sat May 14, 2005 11:36 pm    Post subject: Reply with quote
alix776 wrote:
wishlist how do you mean the post codes dont work could give me more info please as my freinds go 300's postcodes work fine
We were talking about the Classic not the 300. And they do and will work on both with the "file" that this thread is talking about. :P
ChrisCubed
PostPosted: Mon May 16, 2005 9:26 am    Post subject: Reply with quote
I'm awaiting the inevitable i.e. this 'Great_Britain.Postal' file hitting the net.
jeffblockley
PostPosted: Mon May 16, 2005 5:46 pm    Post subject: Reply with quote
Do not buy the map update there is no update in the maps only the full postcodes there are roads in Glasgow that have been there for 3 yrs are still missing.
alix776
PostPosted: Mon May 16, 2005 8:06 pm    Post subject: Reply with quote
jeff have you read mikes response about map data earlier int he thread
device Lumia 950 xl
FazerBoy
PostPosted: Tue May 17, 2005 6:22 am    Post subject: Reply with quote
Should someone be lucky enough to acquire this 'Great_Britain.Postal' file, where does it go or what does it replace on the v5 TTG?
Just interested, thats all!!
Fazerboy
Tim Buxton
PostPosted: Tue May 17, 2005 6:36 am    Post subject: Reply with quote
Naturally it would go where it was installed by the TTN5 map/data installation programme. Joker
Tim
ChrisCubed
PostPosted: Tue May 17, 2005 8:23 am    Post subject: Reply with quote
Should you be lucky enough, I believe it needs to go in a folder named 'zip' in the root directory of the TTG.
FazerBoy
PostPosted: Tue May 17, 2005 5:56 pm    Post subject: Reply with quote
Chris,
I don't seem to have a folder named 'zip'.
I only have two folders showing on my PC thought the SD card. One named 'Great_Britian Navigator Map' which contains the ov2 files and one named 'itn' which contains a temporary itn file.
Where is this 'zip' folder?
Just interested to know!
PostPosted: Tue May 17, 2005 6:55 pm    Post subject: Reply with quote
FazerBoy wrote:
Chris,
You won't have it unless you have the 'upgraded' maps.
rkm_hm
PostPosted: Tue May 17, 2005 7:02 pm    Post subject: Reply with quote
It gets created automatically when you install the updated map.
However, there's nothing stopping you from creating a 'zip' folder yourself if you wish.
FazerBoy
PostPosted: Tue May 17, 2005 11:15 pm    Post subject: Reply with quote
rkm
Not sure how to do that!
As you can gather, my technical knowledge is limited.
Is it easy?
rkm_hm
PostPosted: Wed May 18, 2005 12:21 am    Post subject: Reply with quote
FazerBoy wrote:
rkm
Is it easy?
With TTG connected to a USB port on your computer, it behaves just like an external disk drive. You can create folders on it by selecting it in Windows Explorer and then using the File/New/Folder menu.
Tim Buxton
PostPosted: Wed May 18, 2005 9:16 am    Post subject: Reply with quote
FazerBoy wrote:
rkm
Is it easy?
Since 'acquiring' and using the Postcode zipfile would be illegal by any means other than purchasing it, does it really matter how easy it might be? You are treading on dangerous ground here guys.... Grrrr
Tim
Gus607
PostPosted: Thu May 19, 2005 6:59 pm    Post subject: Reply with quote
Just installed the "ZIP" file from my new SD card to my old card & works fine, although I had to delete a few unwanted voices to make space. The file is 8+ meg and will fit on a 128meg card.
BanziBarn
PostPosted: Fri May 20, 2005 3:03 pm    Post subject: Reply with quote
Does it work?
Page 3 of 4
23.054 (28 May 25)
