andyfoxccp Occasional Visitor
Posted: Thu May 12, 2005 1:47 pm Post subject: TomTom 3 Wired kit - hp2210 - Time to Fix |
Just bought full hp2210 kit with CD etc that has been sat in a draw for almost a year doing nothing!
Installed and activated fine and Ipaq is running latest Rom image and TT3 is 3.07 with 3.07 GPS
What I have found is that the Time to Fix ( initial startup ) seems to be around 4mins or so, which seems long compared to my aging Hiacom 203E attached to Ipaq5450 which is much quicker ( usually within 1 minute )
Could this simply be down to the GPS reciever being in a draw for so long the battery discharged and needing time to charge and sort itself out so it keeps position from day to day. At present only being used for about 10 minutes at start of day and 10 at end.
Much appreciated.
Andy |
andy-c1 Lifetime Member
Joined: Feb 05, 2005 Posts: 1039 Location: East Sussex
Posted: Thu May 12, 2005 4:19 pm Post subject: |
mine can take up to 30 seconds to get going ,never have had to wait that long _________________ TomTom 5001 |
iancjc Frequent Visitor
Joined: 10/02/2003 14:19:44 Posts: 749 Location: United Kingdom
Posted: Thu May 12, 2005 4:38 pm Post subject: |
leave it powered for a few hours then see if it holds its charge - it should do but batteries can certainly die through lack of use. _________________ -----------------------------------------------------------
TyTn II (WM6.1) / tomtom one v2
TTN6.03 tomtom 7.xx (one) |
Posted: Thu May 12, 2005 5:41 pm Post subject: |
Would hard wiring the power to a permanent +ve feed mean the GPS mouse would stay active, considering it is all with the TomTom cradle etc, or is the Mouse only activated once the PDA is inserted?
Is it possible to get replacement TomTom GPS mice or adapter to convert other 'mice' to the TomTom plug?
Thanks,
Andy |
SteveW Frequent Visitor
Joined: 21/05/2003 22:54:59 Posts: 516 Location: Leicestershire UK
Posted: Thu May 12, 2005 11:40 pm Post subject: |
andyfoxccp wrote: | Would hard wiring the power to a permanent +ve feed mean the GPS mouse would stay active, considering it is all with the TomTom cradle etc, or is the Mouse only activated once the PDA is inserted?
Thanks,
Andy |
Not sure what drain this would have on the battery....
A new wired mouse is usually supplied with an adapter/charger cable. The mouse itself will actually have an RJ11 or PS2 connector which connects to the adaptor cable. You can sell the old adaptor on e-bay for about £15. |
MarkHewitt Frequent Visitor
Joined: Nov 16, 2004 Posts: 1077 Location: Chester-le-Street & York
Posted: Fri May 13, 2005 11:51 am Post subject: |
I leave my GPS mouse plugged into the car power permanently. Never had any problems, and it means that as soon as I put my ipaq into the cradle I get a fix straight away. |
