Pocket GPS World :: View topic - France map
France map
Dazp
PostPosted: Tue May 10, 2005 9:00 pm    Post subject: France map Reply with quote
Hi, I'm off to France at the end of May, is there any chance the SD single country version will be available by then? If not, or just supposing I manage to acquire one very late on, are they really just 'plug and play' or will I have to activate it via my PC Embarassed
PostPosted: Tue May 10, 2005 9:36 pm    Post subject: Reply with quote
A single country SD card is 'plug and GO'.
I would copy the SD card to your PC though as there is no CD to do a re-install if anything goes wrong.
Dazp
PostPosted: Wed May 11, 2005 4:22 pm    Post subject: Reply with quote
OK cheers, what if... I cant locate one in this country, but happen to come across a 'France' map in one of the ports or retailers in France etc, can the french version play ok on my UK Go? Embarassed
sgould
PostPosted: Wed May 11, 2005 5:51 pm    Post subject: Reply with quote
You will most likely find a France SD card, if anything. It will probably default the instructions to French when you turn it on. You should be able to change that, but work out which buttons to press (via "change language" in the preferences on you english one first. Unless you can speak French - in which case just use it!!
22.063 (19 Jun 24)
