seasider Lifetime Member
Posted: Sat May 07, 2005 10:18 am Post subject: Importing personal POI from Mapstore to PDA |
Anyone know why the POI created by me and appearing on Mapstore do not appear when the map is exported to my Palm ???? |
Honda Regular Visitor
Posted: Sat May 07, 2005 7:32 pm Post subject: |
Which version on MapSonic/Navigation are you using and which Palm?
By not appearing do you mean that you have created the POI using POI manager, synched and then it does not appear?
Or have you just created it in MapStore and not synched? |
Posted: Sun May 08, 2005 8:18 pm Post subject: POI |
Zire 31
Mapsonic v3.0
Created on Mapstore by clicking on the map and using drop down
Syncd and not appearing although showing on Mapstore map as permanent. |
Posted: Mon May 09, 2005 8:00 pm Post subject: |
Sorry can't help. I have never tried to create a POI in MapStore and then synch it. I have always created on the Palm. |
jblackmore Regular Visitor
Joined: Nov 22, 2004 Posts: 137 Location: Somerset, UK
Posted: Wed May 11, 2005 12:31 pm Post subject: |
Haven't tried v3 but I assume it is the same as v2.51 in this regard.
Exported maps are just maps - they do not have any POIs 'included'.
POIs are not sync'ed between mapstore and Palm when you hotsync, so the only way you can export a POI from PC to Palm is via POImanager using an asc file (the expoted POIs won't show up on Mapstore either, only on the Palm).
Quite why ViaMichelin cannot support syncing POI's I don't know as it should be fairly simple stuff. |
