scott101 Occasional Visitor
Posted: Tue May 10, 2005 3:31 am Post subject: Help with xda 2 mini and sd501 gps |
Hi everybody I have just joined this site and would love some help. I have a XDA 2 Mini and have been trying to get the sdio gps receiver model SD-501 working, it just doesn't pick up any signal at all and i can't see the driver in the list in gps info? can any help me start this please?
Scott |
Pc-Mobile Frequent Visitor
Joined: 26/10/2002 10:38:36 Posts: 789 Location: Hong Kong
Posted: Tue May 10, 2005 4:41 am Post subject: |
It may not be a constructive advice. If your PDA has BT why would you go for an SD GPS instead of BT? Where will you put the maps?
Get a BT GPS and you will have a lot less problem. _________________ Pc-Mobile
http://pc-mobile.net/gps.htm |
Posted: Tue May 10, 2005 5:17 am Post subject: |
i am new to this and didn't know that they had bt as well, but that still doesn't help, i wanted a small size, which is the best and smallest bt gps? |
Posted: Tue May 10, 2005 8:14 am Post subject: |
I can't seem to get this at all, all is it is doing now is annoying me. Can anyone help, the light even blinks when the SD501 is install on the XDA 2 mini but still no com port? |
Posted: Tue May 10, 2005 9:38 am Post subject: |
Be patient.
I have never used an SD GPS so cannot help you.
Most readers have been sleeping since you posted your problem so give it some time.
Anyway you have given very little information in what your problem is so it is difficult for others to give you any advise.
Merely saying that it does not work is no good for problem solving.
For example, how did you install the driver? what software do you use?
what happen when you started the software? etc. etc. _________________ Pc-Mobile
Posted: Tue May 10, 2005 11:17 am Post subject: |
sorry i am normally ok at this sort of thing. Ok the problem is I have a XDA mini by O2 it runs pocket pc version 1.3.00 WWE and i am trying to get the SD-501 working on it. I installed the software on a laptop and a desktop loaded the files as said, via windows xp pro, all the software installed just as i was ment to, but when i opened the GPSinfo the ports that where in the list
com1: serial
com2: serial?_Cmd
com3: IrCOMM
com4: BTIBserial
com5: BTOBserial
com9: Serial_Data
None of those ports would pick the SD-501 up. But when I put the device in(sd-501) the led went red and after a min or two it started to flash, does that mean it has a lock? but the XDAmini didn't pick it up?
So is there more drivers i need? Also I tried to use a different program GPS Tuner and that could not pick up the gps device.
Hope all this helps and it is still flashing in the XDA mini after some time.
And thankyou for you time everyone |
alix776 Pocket GPS Moderator
Posted: Tue May 10, 2005 4:13 pm Post subject: |
what are trying to use the jam for? try winfast navigator as it should work as the mini xda supports sdio if you want use it fir navigation then i would really get a bluetooth gps _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
