Pocket GPS World :: View topic - Copying new maps to existing SD card
Jammy1
PostPosted: Tue May 10, 2005 1:31 pm    Post subject: Copying new maps to existing SD card Reply with quote
New maps should be arriving in a couple of days. I have a 512meg dane-elec SD card at the moment. Ideally I would like to keep using this card, the PGPS test said it was the best one to use on TTGO for speed. Is it just a case of dragging and dropping the new SD card contents onto the old card? Will the new maps overwrite the old ones? I presume I would have to enter an activation code?
PostPosted: Tue May 10, 2005 1:37 pm    Post subject: Reply with quote
Basically all you need to do is to copy the Map folder, though copying the whole SD wont hurt. Make sure you take a backup of your current data prior to overwriting it though.
If you put the new SD into the GO there is a chance that it might self-activate. Not too sure as we havent had the opportunity to test that here.
Cambo
PostPosted: Wed May 11, 2005 1:10 pm    Post subject: Reply with quote
Mike.
What do you mean by self activate. ?
Gordon Campbell
Whitley Bay.
United Kingdom.
PostPosted: Wed May 11, 2005 1:25 pm    Post subject: Reply with quote
By self activate I mean that the activation is included on the SD and will activate itself on the device that you insert it into without additional input on your part. Of course it may not do that.
feenix
Banned
PostPosted: Fri May 13, 2005 2:11 pm    Post subject: Reply with quote
Mine seemed to self activate. I must admit I copied it prior to installing it. i've not had a chance yet though to see if anything changed on install.
