DavebyNet Occasional Visitor
Posted: Mon May 09, 2005 5:58 pm Post subject: Mapopolis and Pharos Bluetooth GPS |
I have an Axim x50v running Mapopolis 4.50.47. I have the Pharos iGPS-BT and I am able to establish a bluetooth connection between the Axim and the iGPS unit.
However, I cannot get Mapopolis to connect to the GPS.
I first establish the BT connection between the Axim and the iGPS. Then I open Mapopolis and go to the GPS screen and hit the Start button. From there the app will continue to try to check each COM port to no avail.
I heard that the Axim uses COM7 for BT connections and I tried to select just COM7 as the port to use but that does not work either.
Any suggestions on what I should do or what I am doing wrong? |
lbendlin Pocket GPS Staff
Posted: Mon May 09, 2005 7:44 pm Post subject: |
Do you see the receiver with any other program (for example Crux_view)?
You don't have TomTom installed, do you? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Mon May 09, 2005 8:09 pm Post subject: |
lbendlin wrote: | Do you see the receiver with any other program (for example Crux_view)?
You don't have TomTom installed, do you? |
No, I only have Mapopolis installed and do not use the receiver with any other programs. Thanks for any help you can provide. |
Posted: Mon May 09, 2005 9:16 pm Post subject: |
have you actually subscribed the PDA to the serial port service of the BT GPS receiver? _________________ Lutz
Posted: Mon May 09, 2005 9:34 pm Post subject: |
lbendlin wrote: | have you actually subscribed the PDA to the serial port service of the BT GPS receiver? |
Not sure how I would do that. What do I need to do to do that? I have an Axim x50v running WM 2003 SE and my receiver is a Pharos iGPS 360 BT. Thanks for your help. |
Posted: Mon May 09, 2005 10:35 pm Post subject: |
in bluetooth manager, do you see the Pharos listed as a device? tap and hold, then say "Connect" Do you get that far? _________________ Lutz
