Pocket GPS World :: View topic - memory card
memory card
paul_j_c2000
PostPosted: Sun May 08, 2005 11:39 am    Post subject: memory card Reply with quote
Hi i have just bought a icn 510 still trying to take it all in,my question is if i want to add the camera data base and any other poi's will they fit on the supplied card i have read somewhere that you have to have a larger card,if this is the case what card do you buy and how do you put all the information from the old card and the poi's on to the new card?i am sorry if this sounds old hat to all you experts but i am a complete novice at all this and would rather ask than get it all wrong ,i have just loaded the software which seemed to go ok it connected to the 510 with the sceen showing usb connected,what is the correct procedure for disconecting the icn510 from the computer i closed all of the open pages but it still had a green circle on the task bar saying connected i tried to turn the nav unit off but it wouldnt in the end i just unpluged it from usb cable is this correct? any help thanks in advance paul
SteadyEddy
PostPosted: Sun May 08, 2005 12:06 pm    Post subject: SD Card Reply with quote
There should be no problem adding POI etc to your existing set up. I have a 510i and have added my own POI together with speed camera POI and still have room.
I have also tried the 510i with a 60x SD 1Gb SD card and it worked fine - not sure how well it would work with a normal speed card.
Simon1
PostPosted: Sun May 08, 2005 8:16 pm    Post subject: Re: memory card Reply with quote
Just unplug the cable from the 510 and it will reboot itself.
22.064 (26 Jun 24)
