Pocket GPS World :: View topic - Go 300 and ASN
Go 300 and ASN
PostPosted: Thu May 05, 2005 8:28 pm    Post subject: Go 300 and ASN Reply with quote
There have been numerous queries regarding ASN and the 300. Some users have reported ASN like effects when satellite lock has been lost and some retailers are listing ASN as a feature of the GO 300.
I can confirm that the GO 300 DOES NOT have ASN, the accelerometers that are part of the ASN system are not present in the hardware and those retailers that list ASN as a feature are incorrect. TomTom have confirmed this is the case.
What you may see when satellite lock is lost is that the map appears to update. What is happening is the unit contunues to draw your location based on the speed and direction you were travelling at when lock was lost. If signal is not reaquired after a few seconds this will cease.
gingernut777
PostPosted: Fri May 06, 2005 6:14 am    Post subject: Re: Go 300 and ASN Reply with quote
Darren,
So if retailers are stating that it DOES have ASN, and your not happy with the Go300, you can take it back for a FULL REFUND, as it's not as advertised, and not for the purpose intended???.
Using an A to Z
Sextant & Compass
Oldboy
PostPosted: Fri May 06, 2005 6:27 am    Post subject: Re: Go 300 and ASN Reply with quote
A very valid point I think.
PostPosted: Fri May 06, 2005 7:35 am    Post subject: Re: Go 300 and ASN Reply with quote
Very possibly. I emailed Comet who were one of those misrepresenting the product. It will be interesting to see if they change the description under 'Uninterrupted Navigation' here.
mediaman
PostPosted: Fri May 06, 2005 6:34 pm    Post subject: ASN Query Reply with quote
I have the original TomTom Go. Can you tell me what ASN actually does? How would I notice whether it's on or off - or whether it's working?
When my unit flashes "ASN" it appears only to be doing what you describe the 300 does - estimating your point based on previous speed and direction.
PostPosted: Fri May 06, 2005 7:28 pm    Post subject: Reply with quote
ASN uses two accelerometers, one for forward movement and one for lateral movement to calculat direction of travel and speed when satellite lock is lost. It's not perfect but better than nothing.
More expensive systems in factory fit systems use a gyroscope and data from the speedometer input to do the same with greater accuracy.
It's intended for use in tunnels etc.
PostPosted: Fri May 06, 2005 8:22 pm    Post subject: Re: Go 300 and ASN Reply with quote
Full marks to Comet, they responded this morning to thank me for pointing out the error and to confirm that it had been corrected.
sgtbanjo
PostPosted: Sun May 29, 2005 9:37 pm    Post subject: Reply with quote
Why does the TomTom 300 have the icon for ASN ghosted out? Surely it shouldn't be there at all if it's not present?
Sarge
PostPosted: Sun May 29, 2005 9:51 pm    Post subject: Reply with quote
Presumably because they all share the same software base I guess.
sgtbanjo
PostPosted: Sun May 29, 2005 9:55 pm    Post subject: Reply with quote
In that case, where are the ghosted out, in car, hands free kit as present on the 500 & 700 ?
Sarge
dill
PostPosted: Sat Aug 13, 2005 9:43 am    Post subject: Reply with quote
Hi sgtbanjo
I assume this is you
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=5796214350&sspagename=ADME:L:RTQ:UK:1
Why are are you asking for free help, when you charge for something that is free, You want it all.
