LizJ Occasional Visitor
Posted: Thu May 05, 2005 6:31 pm Post subject: Problem with TomTom Navigator com1 error. |
I recently had an non-intentional hard boot on my Pocket PC and so have had to reinstall TT Navigator 3. I now have an error message when I launch TT to say that "cannot open COM1 port does not exist". I have a bluetooth GPS receiver.
What have I done wrong? I didn't have this problem the first time I installed it.
Thanks |
alix776 Pocket GPS Moderator
Posted: Thu May 05, 2005 7:56 pm Post subject: |
if your using bluetooth then com1 wont be the port you need to be using if you could let us know which pda an bt gps you have then we could give you better information ton get it going _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Thu May 05, 2005 8:16 pm Post subject: |
alix776 wrote: | if your using bluetooth then com1 wont be the port you need to be using if you could let us know which pda an bt gps you have then we could give you better information ton get it going |
I have an Orange SPV M1000 pocket pc. I and tomtom navigator 3 gps system. The gps receiver is the one that came with the software.
Liz |
Darren Frequent Visitor
Posted: Thu May 05, 2005 8:57 pm Post subject: |
That doesn't help us much as we don't know what receiver you had!
If it plugs into the bottom then it is a GPS Mouse and this normally uses COM1
On the XDA2 and m1000's you get this error if you have 'Receive incoming beams' enabled, goto Start | Settings | Connections - Beam and untick the box.
Now if I had a pound for every time I've answered that one, I'd have oooh £12 maybe ;) _________________ Darren Griffin |
Posted: Thu May 05, 2005 11:48 pm Post subject: |
Hi Darren
Many thanks, I have unticked the beam thing and it now seems to work.
I am not sure how I could have described my gps receiver other than a bluetooth tomtom one.
It doesn't have a plug in the bottom. For future reference, what should I have quoted with reference to the gps receiver?
Liz |
Posted: Fri May 06, 2005 7:40 am Post subject: |
I'm still not sure what receiver you have! If it's bluetooth then the COM1 issue should not occur. Does it look like this?
Or does it look like this?
The first is the TomTom Bluetooth and the second is the TomTom GPS Mouse. _________________ Darren Griffin |
Posted: Fri May 06, 2005 10:10 pm Post subject: |
It's the top one, not the mouse but it only looks like the bottom bit of the top one. It doesn't have the bit that sticks out of the top in your picture.
I have taken off the beam thing you recommended and I don't get the com1 error anymore but the receiver is still not communicating with my ppc.
I have bonded them and tomtom receiver appears but when I run TomTom navigator the condition remains gps postition unreliable.
When the com1 error was there it said gps disabled so there is an improvement but I still can't use it.
thanks for all the help. Any further ideas are gratefully received. |
Posted: Fri May 06, 2005 10:12 pm Post subject: |
What settings have you configured TomTom to use to communicate with the GPS Receiver? For Bluetooth with the XDAII/m1000 it should be COM5. _________________ Darren Griffin |
Posted: Fri May 06, 2005 10:34 pm Post subject: |
Right, bonded it again and the only com port offered to me is com7. |
Posted: Sat May 07, 2005 9:00 am Post subject: |
start up tomtom and going to GPS in the menu uncheck the blue box at the side of this are to other boxes these contain dropdown menus tap the tom one from the drop down menu select TOMTOM WIRELESS GPS highlight this then in the next box down select BLUETOOTH GPS this is the last option in the drop down menu after doing that recheck the blue box turn on the receiver and you should seen some dots moving across the screen and evfentually you shoukld get a fix _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Sat May 07, 2005 12:16 pm Post subject: |
Great! It's back!
Thanks to all who gave advice.
Liz |
funklet Occasional Visitor
Posted: Mon May 16, 2005 11:55 pm Post subject: |
Darren,
In your post the top picture shows the BT GPS in the holder, I have posted elswhere to ask where I can obtain one of these, or a model number of it etc., do you know where I can obtain one, or where you got the picture from? |
Posted: Tue May 17, 2005 12:00 am Post subject: |
Darren,
OK, I can find a picture of one at:
http://www.pocketgpsworld.com/tomtombtgps.php
but, no mention of how to obtain one other than they are / were included in a kit that may or may not have been available a some point.
I already have everything but the holder...... |
