Pocket GPS World :: View topic - Download the Trine datalog
markyd
PostPosted: Fri Oct 08, 2004 7:27 am    Post subject: Download the Trine datalog Reply with quote
I've got a new Emtac Trine, and after some teething troubles with my H3970 and PPC2003 everything is working fine. Really impressed with the Trine!
The thing I am struggling with is the datalogger. How do I download its contents? There are a couple of utilities that came with it on CD but they are basic at best and have no instructions.
Is the datalogger turned ON by default? If so how do I down load the log?
I have a BT USB dongle on the PC so I'm trying to download straight to that, not the PPC.
Is there any other software that will work?
Mark
ajdelore
PostPosted: Tue Oct 12, 2004 7:19 pm    Post subject: Trine Datalogger Reply with quote
The datalogger is not enabled by default. You need to turn it on and view it using their software. You can also set all the parameters -- do you want it to log when position changes by x metres, or after every x seconds, for example. The software is a bit cryptic, but if you work with it you can figure it out.
Unfortunately, there is no Palm (or PocketPC) application. I have used BT Serial Pro to connect to the datalogger from my palm. You could issue commands through this program, and then dump the output to the screen and cut-n-paste it into a memo. Clumsy, but workable.
Anthony
pwwuk
PostPosted: Fri Jan 14, 2005 8:33 am    Post subject: Reply with quote
ll I get is a BIN file with the CRUX_LOG SW .. >> ?? Help ??
SJ
PostPosted: Thu Mar 24, 2005 6:27 pm    Post subject: Reply with quote
I've just received my Trine and in the same position. Has anyone worked what to do with the BIN file?
SJ
adamschneider
PostPosted: Wed May 04, 2005 10:59 pm    Post subject: Reply with quote
GPS Visualizer can now read the .bin files from the CRUX_LOG program: http://www.gpsvisualizer.com/
Let me know if you have any problems.
pwwuk
PostPosted: Thu May 05, 2005 12:33 am    Post subject: Reply with quote
That is because you are a god ! :P
Thank you so much for un wrapping the puzzle..
I know it took many hours to write the importer ..
Let me be the first to say thank you !!
Peter
SJ
PostPosted: Sun May 08, 2005 3:19 pm    Post subject: Reply with quote
Thanks from me too. Works like a treat Trine -> GPX -> Memory-Map.
Cheers,
SJ
