EddieVardo Occasional Visitor
Posted: Mon May 02, 2005 1:17 am Post subject: Check Point 3.2 |
I have TTN 3 on a Hp ipaq 4700 and installed the CheckPoint 3.2
It is set to start and stop with TTN3 but doesn't do anything.
On the menu for settings the SYNCHRONISE is ghosted out and when I go to SYNCHRONISE SETTINGS It asks for my email address (no problem) and then asks for POIplace security code (where do I get this from?) and then to validate.
As you may have guessed, I am new to all of this and will appriciate any help whatsoever. |
Loobster Regular Visitor
Posted: Mon May 02, 2005 12:31 pm Post subject: |
Looks like you need to have a good read of the checkpoint website. Once you register there they send you a security code by email. You put this into your PDA for syncronisation purposes.
I found the FAQ on the site to be very good indeed and in fact answered all the questions I had, including how to record new POIs, which is now programmed into my PDA.
--Loob. |
Robin2 Lifetime Member
Posted: Mon May 02, 2005 5:34 pm Post subject: |
Alternativel you can download Checkpoint v2 free from this site. Many regard this version as better for working alongside TomTom
Robin |
carbon Occasional Visitor
Posted: Mon May 02, 2005 8:44 pm Post subject: |
You need to start checkpoint first as this then starts TT3. When you shut down TT3 this then shuts down checkpoint. Hope this helps _________________ chris
iPAQ 2210: Kingston 512MB SD Card, Holux GR211
TTNav 3.07, GPS Driver 3.07, CheckPOInt 2.0.2.0 |
Posted: Tue May 03, 2005 11:23 am Post subject: |
[quote="Loobster"]Looks like you need to have a good read of the checkpoint website. Once you register there they send you a security code by email. You put this into your PDA for syncronisation purposes.
A big thanx to you & others, I'm now up and running. It was so simple when pointed in the right direction... Cheers |
Posted: Tue May 03, 2005 11:26 am Post subject: Now |
:D A big thanx to you all, I'm now up and running. It was so simple when pointed in the right direction... Cheers |
