Ama Occasional Visitor
Posted: Fri Apr 29, 2005 6:05 pm Post subject: safety camera softwear |
Hi im new to tomtom can any one give me a link to the latest safety camera softwear . ive got a tomtom 300 . and maybe tell me how to install it ? thx Daren |
DavidW Pocket GPS Moderator
Posted: Fri Apr 29, 2005 6:27 pm Post subject: |
It should be the same instructions as the original Go - you use the POI warning feature that's built into Go.
David |
Posted: Fri Apr 29, 2005 6:34 pm Post subject: |
do you have link for softwear? |
Posted: Fri Apr 29, 2005 6:36 pm Post subject: |
You don't need any - as the Database page says: Quote: | Copy the OV2 and BMP files to your Storage Card into the Country Directory (e.g. \Great Britain) and enable them in the POI screen. |
David |
Posted: Fri Apr 29, 2005 7:13 pm Post subject: |
how do i connect tomtom 2 pc? ive plugged in the usb but nothing happens'/ i cant install a driver or nothing HELP :P |
Wonderwall Occasional Visitor
Joined: May 12, 2004 Posts: 40 Location: Birmingham "By M6 toll!!" LOL
Posted: Fri Apr 29, 2005 7:17 pm Post subject: |
You have the disk in right??? |
Posted: Fri Apr 29, 2005 7:33 pm Post subject: |
yes disk is in but cable dont seem to wana pick up |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Fri Apr 29, 2005 8:44 pm Post subject: |
Which windows version are you using? _________________ Richard
TT Via 135 App 12.075: Europe Map v1145 |
Posted: Fri Apr 29, 2005 9:36 pm Post subject: |
xp sp 2 |
kevw Occasional Visitor
Posted: Sat Apr 30, 2005 12:18 am Post subject: |
make sure TTG is turned on - i seem to remember reading there is a new power off function when connecting by USB  |
Posted: Sat Apr 30, 2005 8:32 am Post subject: |
kevw wrote: | make sure TTG is turned on - i seem to remember reading there is a new power off function when connecting by USB  |
If TTG sits idle for several minutes it will switch off.
Ama.
Have you tried plugging into another USB port?
Is it possible to try another USB lead, or use the USB lead on another device (camera perhaps)? _________________ Richard
meditek Occasional Visitor
Posted: Sat Apr 30, 2005 10:51 pm Post subject: |
Don't worry you're not the only one. I've read you need the (non-existent) power supply for it to work reliably. I gave up and used my card reader instead. |
Eldar Pocket GPS Moderator
Posted: Sat Apr 30, 2005 11:14 pm Post subject: |
meditek wrote: | Don't worry you're not the only one. I've read you need the (non-existent) power supply for it to work reliably. I gave up and used my card reader instead. |
I'm not sure that is correct. Mine connects via USB with no external power or any problems at all. If it doesn't connect straight away, turn the unit on, wait for the application to start and then connect the USB cable. |
Posted: Sun May 01, 2005 7:44 am Post subject: |
I've never used the mains power lead for connecting to PC, for anything other than experimenting. The internal battery, if fully charged, lasts several hours. Plenty of time to copy, paste or install. _________________ Richard
bmwman Regular Visitor
Joined: Mar 26, 2005 Posts: 73 Location: Solihull, UK
Posted: Sun May 01, 2005 8:20 am Post subject: |
My process has been to leave the TTG switched off, plug in the cable, then turn the device on.
The device recognises that it's connected and gives a screen showing a picture showing the back of the TTG, and the PC detects the device and shows it as a disk drive in Windows Explorer.
Rich |
