Pocket GPS World :: View topic - Rechargeable AA batteries
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Magellan
Xtreme
PostPosted: Thu Jan 20, 2005 1:48 pm    Post subject: Rechargeable AA batteries Reply with quote
Greetings:
I´m a newbie on this GPS thing. I bought a Magellan SporTrack Map, the european version, just to orient myself when ride bike, and hike by rough country :o . First i want to buy the Garmin eTrex, but everybody said to buy a Cartographic GPS rather than a non cartographic 8O . I follow their advices and bought this, i think for the use i will give to im, its enought. By the way; i´m also going to "explore" the GeoCaching hobbie, because it looks very cool 8).
My question is: can i use rechargeable NiMh bateries on im??? This receiver runs out of bateries very quickly :x.
P.S=Sorry the bad english, but i live in Portugal, and i dont write english very often Embarassed
"Not all those who wander are lost..."
J.R.R. Tolkien
Pocketgps
PostPosted: Thu Jan 20, 2005 7:25 pm    Post subject: Reply with quote
Hello Xtreme
Yes you can, but use high capacity type, 1700 - 2300 Ni/MH types.
You may be able to buy these from a good photo store with a quick charger, your unit uses 2 x AA, so if you buy a charger with 4 x AA then you will have 2 spare as well.
Regards
PocketGps
Pocketgps
PostPosted: Thu Jan 20, 2005 7:29 pm    Post subject: Reply with quote
Hello Xtreme
This is the type i was reffering too
http://www.greatdigitaldeals.co.uk/product_info.php?products_id=8
Regards
PocketGps
Xtreme
PostPosted: Thu Jan 20, 2005 8:06 pm    Post subject: Reply with quote
I´ve got 1800 mAh, 1600 mAh and 1100 mAh, all of them are NiMH type :D. I wil try the 1800, but if the duration doesn´t pass the 10 hours, i will buy 2400 mAh.
J.R.R. Tolkien
AlfGulford
PostPosted: Thu Jan 20, 2005 9:07 pm    Post subject: Reply with quote
Just another vote for the NiMHs. I use the Energizer 2300mAh batteries exclusively and they work great in both my Meridian and digital camera.
Considering how many 'throw-away' batteries they replace they're actually dirt cheap.
Alf
yearnslow
PostPosted: Sat Jan 22, 2005 10:50 pm    Post subject: Reply with quote
how long do the 2400 last alf?
Xtreme
PostPosted: Sun Jan 23, 2005 2:02 pm    Post subject: Reply with quote
Greetings
Today i´ve put for the first time NiMH batteries on my SporTrak Map :D . They were fresh charged, and the voltimeter acused 1.45 v, i know that a regular non rechargeable AA Alkaline batterie have more than 1.50 v :o , and a NiMH have 1.20 V minimum and a 1.48 V maximum (i never reached more than that). The "problem" is that the power graphic show that they are full only at 90% aprox. I believe this apens because of the "internal voltimeter" sees that this batterie have less current that a normal fresh new alkalines. I´m using GP 1800 mAh, but i´m planing to buy 2300 or 2400 mAh Wink.
If i put a high capacity (2300 mAh or more) bateries, does the power situation reach is full capacity:?: Question (100%)
Sory the bad English
Daniel
Pocketgps
PostPosted: Sun Jan 23, 2005 4:39 pm    Post subject: Reply with quote
Hello Daniel
The power reading may not get above 90% even with higher capacity batteries, its reading the voltage, which when switched on is lower than the alkaline batteries as you know.
I would try your system out to see how long it lasts on the 1800mAh batteries, then add about 20-25% for the 2300mAh batteries.
The problem with recharable batteries is there lower voltage as this means that the current drawn is higher than with alkaline.
Regards
PocketGps
AlfGulford
PostPosted: Mon Jan 24, 2005 8:16 pm    Post subject: Reply with quote
yearnslow-
Fully charged, 2300mAh batts will keep my Meridian Color going full time for at least 12 hours with limited backlight use. I've never tried to go longer. The best advice I got from a GPS class was to only turn the unit on occasionally - as needed to get your bearings. Of course, then you don't have the fun of watching the terrain scroll down the screen or have a full track to download, but the batteries will last much longer. I also always carry a set of spare batteries.
There are two disadvantages to the rechargeables that I'm aware of. One is using them in two-way radios. At 1.2 volts the radios don't have quite as much range as 1.5 volt throw-away batteries. But that's OK - I'm still saving a bunch of money.
The other is something I read about in the technical specs webpage of the battery manufacturer (3 or 4 years ago, if it's still accurate). At that time they were saying that the charge diminishes by something like 1/2 to 1% per day. So over the course of a month you might lose 25% of the charge. No problem if you plan ahead. Just be aware of the possibility.
Alf
bobhaack
PostPosted: Thu Apr 28, 2005 6:59 am    Post subject: Rechargeable Batteries Reply with quote
I use the rechargeable NiMH batteries very successfully in my Magellan Meridian Platinum gps receiver. I use the 2300ma capacity batteries and am not afraid to use the backlighting...they have plenty of capacity. Good luck with your gps. Best Regards...Bob//
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Magellan All times are GMT + 1 Hour
23.052 (14 May 25)
