chrismjspencer Occasional Visitor
Posted: Mon Apr 25, 2005 7:02 pm Post subject: voice |
Hi, recently got a navman iCN 610. Trying to put the speed camera maps onto it. Is there anyway u can get it to give you a voice warning when there is a camera approaching??
Helps appreciated guys
Regards Chris |
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Posted: Mon Apr 25, 2005 7:11 pm Post subject: |
Sorry, no. With the 6xx range you are stuck with the 'chime'. _________________ Tim |
Posted: Tue Apr 26, 2005 12:53 pm Post subject: |
In that case, is there any way i can set it to give me an earlier warning of camera's i was almost on top of it by the time it beeped? |
Posted: Tue Apr 26, 2005 1:26 pm Post subject: |
I could have sold you a pup! A 6xx user has changed his default.wav warning. Read here for details.
As to adjusting your warning, this can be done when installing the Custom POIs from the Navman Desktop. On the PPC it can also be done from the device but as I don't have a 600 with V3 on it I can't tell you how to do it from the device, although it should be possible. _________________ Tim |
Darren42 Occasional Visitor
![](modules/Forums/images/avatars/gallery/character_warrior.jpg)
Posted: Sat Jun 11, 2005 12:30 pm Post subject: Changing Alert Time |
Please follow these instructions and you will be able to change the distance for your alert (I have an ICN610 with V3)
From the Main Menu, select 'Setting' then OK, Select 'Alerts' then OK, Select 'Active POI' then OK, Select your Safteycam POI i.e SpeedCam then OK (works with any POI), press the down key 3 times to the 'Distance to POI (ft) and then increase the Distance to POI with the right arrow key. When done press the ESC key.
A warning will be displayed asking if you wish to save the settings, select option required (default is YES), then press OK, now press ESC key twice to take you back to the main menu. Hope this helps. |
