Pocket GPS World :: View topic - Safety camera downloads
Olly1943
PostPosted: Sun Apr 24, 2005 8:15 pm    Post subject: Safety camera downloads Reply with quote
I have downloaded and successfully loaded the safety camera software for my iCN 635, but their are seveal other files witin the csv folder what do they do? Also is there a voice warning for speed camera or just the beep that I get now?
Thanks in advance,
olly1943
icsys
PostPosted: Sun Apr 24, 2005 11:23 pm    Post subject: Reply with quote
Hi, welcome to the forums.
The csv files are as follows:
pocketgps_uk_gatso.csv - entire fixed gatso camera database
pocketgps_uk_specs.csv - additional specs cameras
pocketgps_uk_redlight.csv - cameras located at traffic lights
pocketgps_uk_temp.csv - cameras that are temporary such as at roadworks
pocketgps_uk_mobile.csv - cameras that are not fixed but in specially adapted vans but likely to be in the same location at peak times.
You can choose to install any one or all of the above files.
Instead of the above you can choose to install:
pocketgps_uk_gatso_30 / 40 / 50 / 60 / 70 which are speed related files.
The beauty of these is that you can have a different icon for each file such as a speed icon to tell you the speed limit for the camera.
pocketgps_uk_gatso_tba.csv are the rest of the cameras, to make up the full database, for which the speed is not currently known.
The pocketgps_uk_mobile_30 - 70 are exactly the same but for the cameras that are mobile.
You will need to install ALL the speed range 30-70 PLUS the tba file
pocketgps_continental.csv - are known speed camera locations in continental Europe.
You can change the Custom POI warning to another sound of your choice but it will require access to the devices system files. The same sound will play for ALL POI's that you set to give an audible alert.
On an iCN, the POI alert sound is called default.wav
Via ActiveSync, locate the default.wav file. It should be in the following directory:
/storage card/Navman/MyPOI/
Rename the file to default-old.wav or silmilar.
Locate the Sound directory, Cut and paste your chosen file into it.
I dont have an iCN6xx so cannot help with installation but if you have problems just post back and i'm sure someone with an iCN6xx will be able to help further.
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
22.094 (25 Sep 24)
