Pocket GPS World :: View topic - XDA11- Best GPS Package
Paynetec
PostPosted: Sat Apr 23, 2005 10:45 am    Post subject: XDA11- Best GPS Package Reply with quote
Planning to purchase a GPS system for my XDA2 so will need both hardware and software! Any suggestions or better go for a standalone system? Can I use the radio auto mute so I can here the GPS talk? What leads/mounts etc do i need?
Many thanks in advance for help
Paynetec
alix776
PostPosted: Sat Apr 23, 2005 7:49 pm    Post subject: Reply with quote
either tomtom or copilot will run on the xda 2 with out problem over bluetooth or wired just make sure the rom version is 1.72 downloading pocket bluetooth tools makes a big bifferent to the bluetooth conection and id remcomend downloading and installing it before pairing the gps receiver you can use a headset and a gps over bluetooth at the same time if you want a mount with gps built in then i recomend the cr-100 from holux and is compatible with xda2 and xda2i hope that helps a little
device Lumia 950 xl
Paynetec
PostPosted: Sun Apr 24, 2005 10:10 pm    Post subject: Holux CR100 Reply with quote
Many thanks for the reply, will give the holux a go!!
xda
PostPosted: Mon Apr 25, 2005 9:34 am    Post subject: Reply with quote
I would surjest that you have a read of the Holux Forum prior to purchasing a Holux CR 100 as there are problem with it and the phone on the XDA II.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
alix776
PostPosted: Mon Apr 25, 2005 12:48 pm    Post subject: Reply with quote
xda i haven't had any problems at all with the cr100 & the xda2i my father hasnt had any prblems with his unit either
device Lumia 950 xl
xda
PostPosted: Wed Apr 27, 2005 11:53 am    Post subject: Reply with quote
If you scan through the Holux CR-100 forum you will see the problems that have been posted. With the phone turned on and the XDA II in the cradle you get feedback from the speaker amplifier circuit which distorts the TomTom's voice directions. I have had 2 of them here and both had to be returned. Turning off the phone is a cure but totally defeats the object of having it, if you can't receive or make hands free calls whilst on the move.
Graham.
Nokia 925 Windows 8
alix776
PostPosted: Wed Apr 27, 2005 2:18 pm    Post subject: Reply with quote
if you put any mobilephone next to a speak you will get some feed back its not limited to the cr100 my arkon muti media mount di the same h=ive probems using it as i use a bt headset with it its a powered mount with a gps receiver built in its not designed to be used as a car kit as said before ive had no problems with voice from tt or any other navigation app whilst using the phone the is a small amount of feedback but you cant get a away from it
device Lumia 950 xl
22.071 (03 Jul 24)
