cvilhena Occasional Visitor
Posted: Wed Apr 20, 2005 8:30 am Post subject: Axim x50v BT-318 PROBLEM! |
I`m getting crazy!!!
Can`t make my Axim x50v work with BT-318.
Bluetooth connection seems to connect, GPS blue led blinks faster, but cant make any kind of software to receive the signal. Even GPS info isn`t working correctly, it only shows the first screen and I cant see the Globe screen.
Tried GPS Tuner and even it wont work.
Please, can someone give me a step by step setup ( even if I need a Hard reset).
Thank you in advance.
- Christiano |
EasyD2 Regular Visitor
![](modules/Forums/images/avatars/1657901726438c327304bf8.gif)
Posted: Wed Apr 20, 2005 2:38 pm Post subject: |
Hi, I still canīt connect...
The problem is the setup doesn't look the way my Axim is configured.
Where de guide says: " Bluetooth mannager will ask you if you want to connect..." My screen only have: "Bluetooth mannager: Bluetooth My Shortcuts, and a menu where says NEW, and when you click it brings a new screen called "Bluetooth connection wizard", where the only option fot GPS would be "Explore a Bluetooth device", and if you select the GPS it will brings another screen with the "Service selection" and there I have the option to select the only one availiable "BT-GPS Com port", with a checkbox "use a secure encrypted connection", do i need to check this box?.
Well as you can see my doubt is that, do a need to have the GPS paired or just the service dicovered? what is the best solution?
Do I need to leave the GPSinfo program running or not?
thank you,
- Christiano |
Posted: Thu Apr 21, 2005 10:42 am Post subject: |
Yes, it is best to pair/bond the device.
Make sure you are not using GPS Info and TomTom at the same time.
Quote: | I have the option to select the only one availiable "BT-GPS Com port", with a checkbox "use a secure encrypted connection", do i need to check this box?. |
The BT-GPS Com port you see available is the correct one. And no you don't have to check the box for encrypted connection. _________________ www.easydevices.co.uk
Tel: 0871 7000 156
Globalsat UK Distributor |
