Pocket GPS World :: View topic - suppress POI's duplicates
cdelecole
PostPosted: Mon Apr 18, 2005 12:21 pm    Post subject: suppress POI's duplicates Reply with quote
Hi there !
I have a POI file containing duplicate entries.
Any good soft to able me to delete duplicate entries in such a file ?
Thanks !
Oldie
PostPosted: Mon Apr 18, 2005 4:57 pm    Post subject: Reply with quote
Have a look at my POIManager program. The latest version is available in the Programs area on my website http://rjdavies.users.btopenworld.com
Various TomToms, Garmin eTrex Legend, GPSMAP 60CSx, Oregon 550t, Forerunner 405
cdelecole
PostPosted: Fri Apr 22, 2005 11:46 am    Post subject: Reply with quote
Thanks. Oldie, but there is something I don't understand.
When merging a master file with an update filem and unselect the radius <1 and <20 ...
I understand the "Save as new entry" will keep the dupliacte with name entered in the "First matching Entry" group.
Skip is certainly going to skip the duplicate entry and not put it in the output file
... but what is "Position, Text and Both" ?!?
Cedric.
Oldie
PostPosted: Fri Apr 22, 2005 12:23 pm    Post subject: Reply with quote
These buttons allow you to change the Master entry. It is possible to edit the text associated with the update entry. So this modified text can be used to replace that in the master entry by selecting the <Text> button. The update coordinates will be used if the <Position> button is used. <Both> will use the coordinates and text associated with update instead of those of the master entry.
That is the theory anyway. In practice I used POIManager mainly for duplicate checking of a Master file and extracting new entries from an Update file (ie with Append unchecked). I ended up not using the Position, Text and Both buttons.
cdelecole
PostPosted: Fri Apr 22, 2005 1:03 pm    Post subject: Reply with quote
Thank you,
But what is that difference between the "Append" checked or not ?
Means will keep the Duplicate entries or not ??
Oldie
PostPosted: Fri Apr 22, 2005 1:28 pm    Post subject: Reply with quote
With Append checked the Output file will have the Master file entries and the retained entries from the Update file.
With Append unchecked only the retained entries from the Update file will be sent to the Output file.
22.094 (25 Sep 24)
