Tomh26 Occasional Visitor
Joined: Apr 10, 2005 Posts: 12 Location: Runcorn, Cheshire
Posted: Thu Apr 14, 2005 3:43 pm Post subject: |
all done :D cheers |
Boblites Occasional Visitor
Posted: Thu Apr 14, 2005 4:54 pm Post subject: |
Hi everybody, hope you will welcome another dumb user who is having a problem trying to install V5 on a TTG.
I have downloaded the upgrade and after clicking on the setup.exe file the TomTom screen opens. I then follow the instructions but all the application wants to load is the Jane voice. Anyone know what I am doing wrong as this is driving me nuts and I am beginning to regret selling my Mio268 and buying a TomTom. |
pawsey Occasional Visitor
Posted: Thu Apr 14, 2005 5:43 pm Post subject: |
Just a thought
Did the file you downloaded have the filename: ttgoupg500.exe ? This is the upgrade setup file...
If the file you downloaded has the filename setup.exe, then that is possibly the wrong file. The upgrade file is 5,570KB in size. |
Markie Occasional Visitor
Posted: Thu Apr 14, 2005 6:14 pm Post subject: |
Have you tried loading / removing different voices in from the original cd that came with the go? |
Posted: Thu Apr 14, 2005 7:44 pm Post subject: |
guys all the new features seem to have added fine, but the postcodes are still doing the same ?? EG its only letting me do w13 6 and then wont let me add anymore ! all the new options are there like it says on the page  |
squigles Regular Visitor
Posted: Thu Apr 14, 2005 7:56 pm Post subject: |
Tomh26 wrote: | guys all the new features seem to have added fine, but the postcodes are still doing the same ?? EG its only letting me do w13 6 and then wont let me add anymore ! all the new options are there like it says on the page  |
That's because v5 is not a full update, if you want to have FULL POSTCODE SEARCH & CONGESTION CHARGE/TOLL ROADS then you have to wait until May when you have to buy the map udates for most of the new functions in v5 to work 8O |
kk Occasional Visitor
Posted: Thu Apr 14, 2005 7:57 pm Post subject: |
Quick question before I attept the upgrade...is the map activation code the 10 digit number printed on the sd card case i.e. 2XXX.XXX.XXX |
Posted: Thu Apr 14, 2005 8:01 pm Post subject: |
kk wrote: | Quick question before I attept the upgrade...is the map activation code the 10 digit number printed on the sd card case i.e. 2XXX.XXX.XXX |
That's it kk :D |
Posted: Thu Apr 14, 2005 8:41 pm Post subject: |
squigles wrote: | Tomh26 wrote: | guys all the new features seem to have added fine, but the postcodes are still doing the same ?? EG its only letting me do w13 6 and then wont let me add anymore ! all the new options are there like it says on the page  |
thank you very much sir :D |
Posted: Thu Apr 14, 2005 8:44 pm Post subject: |
Hi pawsey,
Thanks for your reply. Yes the file had the name ttgoupg500.exe. I unzipped this file and then clicked the setup.exe and the result was it loaded Janes voice and nothing else. I have deleted the download file 3 times and re-downloaded it in case there had been an error but it still did the same thing.
I have done as Markie has suggested and used my original CD to load/delete voices and this worked OK and saved me space on the SD card, which is the original 128 Mb TomTom card version 4.2 which has only got a camera database added.
So I am still open to any further suggestions, but be polite please. |
JackieHigh Occasional Visitor
Posted: Fri Apr 15, 2005 1:40 am Post subject: |
Hi Boblites
I also had this problem but found that when i removed the original CD from the drive and then double clicked the downloaded file it worked fine. Hope this helps.
Jackie  |
Posted: Fri Apr 15, 2005 12:53 pm Post subject: |
Thanks a lot to keefy and JackieHigh, did as you suggested and removed CD from drive and Hey Presto installed with no problem.
Once again many thanks to all who have taken the time to help me sort the problem and I'm sure this will help others. |
spacerunner Occasional Visitor
Posted: Sun Apr 17, 2005 2:02 pm Post subject: TTG Ver 5:00 |
I downloaded and installed the upgrade with no probs at all. I am very impressed with the 'Itinery' feature as it was the only serious niggle i had with ver 4:40. However I have noticed that since the upgrade TTG has taken longer to pick up sattelite connection. Anybody else noticed this? |
gingernut777 Frequent Visitor
Joined: Nov 03, 2004 Posts: 251 Location: Earth where else
Posted: Mon Apr 18, 2005 6:46 am Post subject: Re: TTG Ver 5:00 |
spacerunner wrote: | I have noticed that since the upgrade TTG has taken longer to pick up sattelite connection. Anybody else noticed this? |
No difference with mine. _________________ Using an A to Z
Sextant & Compass |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Mon Apr 18, 2005 7:43 am Post subject: |
Mines the same as before. _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
