Pocket GPS World :: View topic - Alpha release of GPSMap-OS, freeware moving map software
shanks
PostPosted: Thu Nov 04, 2004 11:18 pm    Post subject: Alpha release of GPSMap-OS, freeware moving map software Reply with quote
After many, many hours of hard work I've released an alpha version of my latest programming project, a PocketPC 2003 program to read output from a GPS receiver and plot your position on an "OS map".
Here's the homepage:
http://www.craporola.com/GPSMap.html
Important note to non-UK viewers: This version only supports plotting on maps using the British National Grid (OSGB) projection. Support for other grids/projections may be incorporated in the future.
I need your feedback - whether positive or negative, particularly if you get this program to work with your hardware. I've only been able to test this with my own kit (Ipaq 2210 and TomTom Bluetooth GPS receiver).
Enjoy!
dr. matt
PS. Don't ask me for maps. I'm sure you're resourceful enough to make your own Wink
BlueJay
PostPosted: Fri Dec 03, 2004 3:46 pm    Post subject: Reply with quote
dr. matt,...
I am not so much interested in plotting the OSGB on a moving map, but rather work form current location to next waypoint.
Showing current position, distance and bearing to next waypoint, current speed, SOG etc etc.
Track could be usefull as well but not required.
thnx
RJ
gacrane
PostPosted: Fri Dec 17, 2004 6:44 pm    Post subject: Reply with quote
Thanks shanks I'll give it a try over the Xmas break and see how I get on with it. :D
Paulb222
PostPosted: Thu Apr 14, 2005 5:11 pm    Post subject: A couple of points... Reply with quote
This seems to be a very useful app, but...
How do I know when I have got a satelite fix?
Why does it keep crashing on my iPaq 5450 with PPC 2002 - is it to do with me using a JPG as my map?
Should I be using the 'static' or 'dynamic' download.
thanks
PAUL
Getoffandwalk
PostPosted: Wed Jul 06, 2005 2:56 pm    Post subject: The WCE4 version works perfectly on my Acer n35 Reply with quote
The WCE4 version works perfectly on my Acer n35 (OS=4.20). :D
The facilities provided, intuitive feel and ease of use are commendable.
Tips
1. The Acer n35 GPS Connection Baud Rate is 57600.
2. To release the GPS connection. Close Destinator before tapping GPS/Connect in GPSMap. From GPSMap, tap GPS/Disconnect or use file/exit before starting Destinator.
3. The Acer n35 screen is about 114 pixels per inch. To keep the same map scale on screen, scan maps at 300 pixels per inch, then scale to 114 pixels per inch and convert to PNG with save as. I use MS Picture It!
4. To save on memory reduce the map's bit depth to 8.
23.054 (28 May 25)
