barrowfordred Regular Visitor
Joined: 04/09/2003 21:03:05 Posts: 79 Location: Barrowford, Lancashire
Posted: Thu Jul 29, 2004 9:37 pm Post subject: BT-308 reset |
I am currently in the process of resetting my BT-308 to regain NMEA, not sure this is worth it but......... anyway, the battery has run down to the point were all the LED's have turned off. How much longer do I need to leave it?
Thanks. |
Mehanik Occasional Visitor
Joined: Jun 09, 2004 Posts: 26 Location: Moscow, Russia
Posted: Fri Jul 30, 2004 8:49 am Post subject: |
Leave it for 15-20 hours. _________________ Mikhail E. Veselov
http://www.globalsat.su
GlobalSat Russia |
Posted: Fri Jul 30, 2004 10:08 am Post subject: |
Thanks for that, I assume I then need to make sure that TomTom is set to NMEA or it will change back???????
Does the external receiver supplied run with SiRF????????? |
Posted: Fri Jul 30, 2004 4:53 pm Post subject: |
Been off now for 48 hours, started the bluetooth connection, started GPS Info, Com port 8, baud rate 38400, start GPS, cold start = $PSRF...OK, then nothing....................................
Scan Com port would appear to nothing also, when this is clicked nothing at all happens? |
crypto Occasional Visitor
Posted: Thu Sep 02, 2004 9:44 pm Post subject: use TomTom to switch to nmea |
Can't guarantee it will work but I had the same situtation. At the end everything worked. If I recollect well the last thing I did was switching from sirt to nmea in TomTom. Kill TomTom and start GPSinfo. It found it immediately.
Ron |
Steve999 Regular Visitor
Joined: Jun 20, 2004 Posts: 160 Location: Lincolnshire, England
Posted: Fri Sep 03, 2004 8:43 am Post subject: |
I seem to remember that there was an issue with some BT-308 units that when switching back from Sirf, you need to select NMEA 01832v2 38400 rather than 4800 otherwise it wouldn't play. Try that.
You could also try Winfast Navigator and do a factory reset within that. Would still recommend you select 38400 first after the reset though.
Steve _________________ Google Pixel 4a 5G Handset
Sygic
CoPilot
Nissan Connect
