Pocket GPS World :: View topic - Basecamp map
Basecamp map
DeeSee
PostPosted: Sat Oct 21, 2017 2:41 pm    Post subject: Basecamp map Reply with quote
Hi folks,
Just downloaded Basecamp and having a play. Can't work out to get Basecamp to use my europe map without device plugged in (only global visible).
I used Express to download my map to my PC (my usual download directory) then moved it to Prog Files x86 Garmin Basecamp Maps (where global basecamp map is located) . Basecamp doesn't see it.
I then dropped my map to an empty USB stick and tried that. Basecamp doesn't see it.
Don't really want to mess with Basecamp too much with my device plugged in in case I manage to inadvertently foul my Nav up.
Anyone know what I have to do to use Basecamp with my map but without my Nav plugged in?
DeeSee
PostPosted: Sat Oct 21, 2017 3:17 pm    Post subject: Reply with quote
Me again,
Powered down PC, then up again. Basecamp now sees my map (the one on the PC) without Nav plugged in??????
Don't know why this stange behaviour but I can now play with impunity (if map doesn't disappear).
PostPosted: Sat Oct 21, 2017 3:42 pm    Post subject: Reply with quote
Don't normally need to power off/on for BC to see map but do need to close/open it. BC will only see map on usb stick if in a folder named Garmin.
DeeSee
PostPosted: Sat Oct 21, 2017 4:19 pm    Post subject: Reply with quote
Thanks sussamb,
Maybe I didn't reboot Basecamp and obviously did when I shutdown/restarted.
Will amend my USB stick but works fine from C drive for now so will run with that.
22.054 (22 May 24)
