Pocket GPS World :: View topic - Settings Help
Settings Help
Post new topic   Reply to topic    Pocket GPS World Forum Index -> CamerAlert on Android
FrequentFlyer
PostPosted: Mon Jun 17, 2013 8:39 pm    Post subject: Settings Help Reply with quote
I keep meaning to request a bit of help 'cause I'm getting a bit frustrated.
When a camera is detected, the Red box comes up as a warning, but, instead of it only showing for a couple of seconds or so, far too quick, how do I set it up such that it remains showing until I literally hit the camera, maybe 500/1000 yards away?
It disappears far too quickly for me and I don't use the CamerAlert map option as I'm either using Sygic or CP8. Thanks.
PostPosted: Mon Jun 17, 2013 10:43 pm    Post subject: Reply with quote
Do you mean when the red box pops up over the top of another app?
If so then these are called 'toasts' and Android only allows these to be 2 seconds at most. The default is 1 second but in the settings you can adjust this to be longer ('longer pop up alerts' or words to that effect).
If you turn on overspeed warnings then you will get a speed limit pop up if you ever creep over the speed jst in case you didn't see what the limit was.
Hope this helps?
FrequentFlyer
PostPosted: Tue Jun 18, 2013 9:44 am    Post subject: Reply with quote
So, what is the shortest or optimum distance from a camera should I set the App up to, so that the 2 second Red Box displays as close to the camera as possible. At the moment mine flashes up and then I'm looking for a camera for the next .????? Or should I carefully set up CP8 and Sygic to somehow tie in with the red box ?
The overspeed warning bit is fine.
PostPosted: Tue Jun 18, 2013 10:28 am    Post subject: Reply with quote
Personally I have the camera warning set to 30 seconds with an extra 10 seconds for mobile sites.
253
PostPosted: Tue Jun 18, 2013 10:56 am    Post subject: Reply with quote
Worth mentioning that if you set up the warnings to close to the camera, then you will have been pinged and if over speed you will get a ticket.
The red pop up warning (toasts) feature is limited by Android, like MaFt says.
My preference is to have my warnings set long, and then add another 20 secs for the mobiles. I know the red pop has been and gone long before I get to the camera, but it is my responsibility to make sure i adjust my speed.
Possible camera positions are usually bridges or laybys, so again you can mostly spot them.
Once you are past the camera location you get an "All clear" verbal from CA so you know you are past the camera.
Works for me, but everyone is different.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> CamerAlert on Android All times are GMT + 1 Hour
