Pocket GPS World :: View topic - Ipaq 2210, USB cradle, Activesync...
WebAgents
PostPosted: Fri Jun 25, 2004 11:31 pm    Post subject: Ipaq 2210, USB cradle, Activesync... Reply with quote
When I dock my ipaq, activesync kicks in and does it's thing. I then switch IPaq off. But when I look later, IPaq is powered on again on the today screen with backlight on.
Why does it turn back on and how do I stop it?
Regards
BH
Darryl
PostPosted: Fri Jun 25, 2004 11:59 pm    Post subject: Reply with quote
BH - i think it is either something to do with the battery being full as mine switches itself on in the cradle (intermitently) if not could it be that a reminder from the calendar is switching it on to make you aware of an appointment Question
WebAgents
PostPosted: Sat Jun 26, 2004 12:46 am    Post subject: Reply with quote
I don't use the calendar at the moment so not that. Battery full sounds possible. What a wate of the backlight though.
Regards
BH
Spudd
PostPosted: Sat Jun 26, 2004 9:12 am    Post subject: Reply with quote
I think it has something to do with ActiveSync, when it knows that there is a ppc in its cradle, it sends a wakeup signal to the ppc every 10-15 mins in order to sync.
Try going into ActiveSync's options, Schedule tab, and change "When connected to my pc sync" From continuously to On Connection, and see if that helps.
You can also adjust the power properties in Advanced, you can select to Turn off device if not used for ... On external power, so that when ActiveSync turns on your Ipaq, it'll turn itself off after a min or so.
Tim
WebAgents
PostPosted: Sat Jun 26, 2004 8:21 pm    Post subject: Reply with quote
Done, Hope it works :D
I can't do this because if and when I power the ipaq from the car whilst driving, it would switch off and I'd lose tom tom and then my way Joker
Regards
BH
22.063 (19 Jun 24)
