M8TJT The Other Tired Old Man
![The Other Tired Old Man The Other Tired Old Man](modules/Forums/images/ranks/verifier.gif)
![](http://maft.co.uk/avatars/m8tjt.jpg)
Posted: Fri Sep 30, 2011 7:48 pm Post subject: PC Networking |
I have two computers and a gigabit NAS the desktop and NAS, both gigabit LAN ports, are connected by a gigabit switch that is fed from my router by a 10/100 ethernet cable. My lappy (has GB ethernet but not used) is connected to the router by its internal wirelesG access point. The lappy has the capability of wirelessN so I was thinking of buying a WirelessN access point to connect to my router or switch.
The access point I had in mind was this one.
The problem that I have trouble getting my head around is that it's advertised as 300Mbps (I realise that this figure is not achievable), but how can it be a nominal 300Mbps if its input is a 100Mbps ethernet port?
Any thoughts anyone? |
JimmyTheHand Frequent Visitor
![](modules/Forums/images/avatars/5363190734ddc119bb3cfd.jpg)
Posted: Sun Oct 02, 2011 8:34 am Post subject: |
the 300mbps is merely a measure of the max wireless connection speed and
could potentially be achieved if both sender and receiver are connected to wireless. If it is connecting from wireless to the Ethernet port then the incoming data will be buffered until buffer is full at which point the handshaking will send a pause message back - depending on how good the buffering is, depends on how fast things run
Note some N adaptors are only 150 mbs
Have you looked at replacing the router instead - you can get ones with built in gigabit switches and 300bps wireless - so could potentially have one device on instead of three _________________ J. |
Posted: Sun Oct 02, 2011 9:26 am Post subject: |
Thanks for coming back to me Jimmy and the explanation. JimmyTheHand wrote: | the 300mbps is merely a measure of the max wireless connection speed and
could potentially be achieved if both sender and receiver are connected to wireless. | Ah, I see. JimmyTheHand wrote: | Note some N adaptors are only 150 mbs | And presumably this will also depend on my lappy's N implementation. It's too b***** complicated JimmyTheHand wrote: | Have you looked at replacing the router instead - you can get ones with built in gigabit switches and 300bps wireless - so could potentially have one device on instead of three | Yes, but as I already have the 10/100 Mb router (and two 'spares) and the GB switch, I thought that I could upgrade my wireless to N for £20-30. I must look into an N/GBb router and to hell with the expense.
But the main problem that I was having, and hence the original question, was that of the claim of 300Mb/sec when fed with a 100Mb/sec source.
I suppose this is similar to the ISP speeds of 'Up to 8 Mb/sec'. I think I am lucky with just over 6 to the exchange, but it's a lot slower data rate when my ISP, Orange, throttle back access speeds during 'peak' times ![Sad](modules/Forums/images/smiles/icon_sad.gif) |
Posted: Sun Oct 02, 2011 12:22 pm Post subject: |
M8TJT wrote: | I could upgrade my wireless to N for £20-30. I must look into an N/GBb router and to hell with the expense. |
Unless you have to transfer large amounts to/from laptop or there are signal issues in house/garden - I am not sure there is a lot to gain (and if it is just transferring data occasionally - then usb hard disk/plugging laptop into cable is what I do)
If not in a hurry - it is worth watching Amazon prices as sometimes large savings (just make sure you get the right type of router) - worth asking in thinkbroadband.com as often some knowledgeable people there (and some less so)
M8TJT wrote: | And presumably this will also depend on my lappy's N implementation. It's too b***** complicated |
Yes I am afraid so _________________ J. |
Posted: Sun Oct 02, 2011 5:46 pm Post subject: |
I think that I will do as you say and extend my GB ethernet cable through the wall so that I can use it for file transfer when needed, and use the wirelessG for internet access etc.
As you say, I don't think I will gain much of an advantage by going wirelessN as the improvement will be nowhere near as much as hard wireing, which goes like hot snot on file transfers. |
