Pocket GPS World :: View topic - Mount confusion
Mount confusion
PostPosted: Tue Mar 15, 2011 11:06 am    Post subject: Mount confusion Reply with quote
I'm looking at getting a cheap Garmin as my Talex subs have finally run out.
I'm looking at the 2200 or 2240 as I don't want widescreen for what will essentially be a pseudo SCD.
I've downloaded the user manual that shows the unit being on an active mount and the power cable being plugged into the mount.
Other pictures I've seen have the power cable being plugged into the unit itself.
which is right ?
ta
Car Average MPG :
PostPosted: Tue Mar 15, 2011 2:24 pm    Post subject: Re: Mount confusion Reply with quote
Which manual are you looking at? I just tried two and..
The Quick Start Manual for the nüvi® 2200/2240/2250 shows (on page 3) that those models have a passive mount.
But the full Owners Manual for the nüvi® 2200/2300 series covers both model ranges, and on page 3/4 it shows the mounts are different.
PostPosted: Wed Mar 16, 2011 7:36 am    Post subject: Reply with quote
The PDF that was confusing me is:
http://static.garmincdn.com/pumac/nuvi_2200_2300_2400_EN_OM.pdf
Page 3, but page 6 does highlight the differences.............
I think the 2310 is probably a better bet and looks like an active mount
Car Average MPG :
PaulB2005
PostPosted: Wed Mar 16, 2011 8:11 am    Post subject: Reply with quote
Well I've read the manual and I'm no clearer why they use two different types of USB port. The table on page six does little to help. In the past the poet on the unit was the same type as the port on the mount.
PostPosted: Wed Mar 16, 2011 8:52 am    Post subject: Reply with quote
I commented on this in my recent 2630 review.
I suspect that all newer models will be using MicroUSB on the device itself but that the active cradles are an existing design hence miniUSB. In time it is reasonable to assume that they will be re-designed with microUSB as we move to this as the standard on many devices.
PaulB2005
PostPosted: Wed Mar 16, 2011 8:54 am    Post subject: Reply with quote
Sorry. Sad
PostPosted: Wed Mar 16, 2011 9:00 am    Post subject: Reply with quote
Smile I was just saying that I think it's an issue that will be resolved once stock of the older mount is used up. Otherwise it is just daft to have two separate connector specs.
pillboxman
PostPosted: Wed Mar 16, 2011 8:36 pm    Post subject: Reply with quote
I do not know if this will help, I have just got a 3790T and this uses the same micro USB for both the active mount and plugging straight into the unit, depending how you want to power it.
PostPosted: Thu Mar 17, 2011 7:56 am    Post subject: Reply with quote
Thanks Smile
Car Average MPG :
PostPosted: Sat Mar 19, 2011 7:42 am    Post subject: Reply with quote
Continuing on............
Would one of these power a Garmin OK in the car to save having the rather large 'lump' hanging out of the ciggy socket?
http://www.amazon.co.uk/Belkin-Micro-USB-Adaptor-F8Z445EA/dp/B002C3AFHG/ref=pd_cp_ce_0
I realise I would need a USB charge lead.
Car Average MPG :
PostPosted: Sat Mar 19, 2011 10:10 am    Post subject: Reply with quote
Yes but you'd lose TMC Traffic.
PostPosted: Sun Mar 20, 2011 7:40 am    Post subject: Reply with quote
Thanks, no problem because my Honda built in job has TMC traffic, plus I run a Trafficmaster Q-Busta.
I'm getting there Smile
Car Average MPG :
inspiredron
PostPosted: Wed Mar 23, 2011 12:46 am    Post subject: Reply with quote
Remember that with the mini USB type units a normal usb lead will put the unit into mass storage mode and it won't then work as a navigation device. Garmin usb leads have the outer part of the plug attached to data ground or power ground (I'm not sure which). Without that (non standard) connection the power lead will fool the unit into thinking it is connected to a PC. I guess that the micro usb leads need this connection too.
PostPosted: Wed Mar 23, 2011 7:43 am    Post subject: Reply with quote
Thanks for that Smile
So, if I understand right, ensure I have a proper Garmin USB lead ?
This arrived yesterday and works OK in the car (LED is lit to show power is OK).
http://www.amazon.co.uk/gp/product/B002HRU7F2/ref=oss_product
Car Average MPG :
PostPosted: Wed Mar 23, 2011 8:32 am    Post subject: Reply with quote
That should work fine, as that's simply providing a USB socket, and some 3rd party leads work fine too, others don't. You can either experiment or buy the Garmin lead to be sure it'll work, but of course they are far more expensive Sad
22.094 (25 Sep 24)
