Pocket GPS World :: View topic - PocketGPS cams not importing on Copilot 8, Android 2.1
scote
PostPosted: Mon Apr 12, 2010 8:09 pm    Post subject: PocketGPS cams not importing on Copilot 8, Android 2.1 Reply with quote
I was having a problem where it appeared that only the Gatsos were bejng loaded following the instructions here:
http://www.pocketgpsworld.com/uksafetycameras-copilot8.php
I got the startup message saying the pois had been integrated, then cancel button, another progress bar or three, but no more messages about POIs being integrated. just the cancel button which you have to press to move to the next stage.
After searching the forums to no avail I decided to try a few things on my own so I decide to load up one category file at a time and found that after each restart of copilot I get a message about integrating the POIs, the cancel button did not appear this time.
This seems a solution to installing "consolidated by type" ie copy one pair or files (png and csv) at a time start copilot, then exit, repeat until all desired files have integrated.
If anyone else can confirm this as a fix perhaps the mods here can get a note added to the above guide to help others?
BaggieBoy
PostPosted: Mon Apr 12, 2010 10:31 pm    Post subject: Reply with quote
Importing multiple files has always been broken on the Android version, I've always had to do them one category at a time.
22.054 (22 May 24)
