Pocket GPS World :: View topic - I can no longer "Export" the .map files - ?
PloddinPedro
PostPosted: Mon Apr 20, 2009 2:01 pm    Post subject: I can no longer "Export" the .map files - ? Reply with quote
Is my memory at fault? I thought I used to be able to "Export" via SatSYNC the smaller .map files, which would save on my hard drive as .gpx files. I can still use "Copy file from Active 10" to download the full "raw" version, but now the "Export" option is always greyed out and if I copy/save the .map version as a .gpx file it won't open in either Memory Map or Garmin Mapsource - what's going on?
LostMike
PostPosted: Mon Apr 20, 2009 3:40 pm    Post subject: Reply with quote
The current version of Satsync only exports from memory and not the SD card. And the latest version of the A10 software automatically saves the .map file on the SD card....
I suspect that if you copy or move the .map file to internal memory then it will export at it used to.
Good luck.
LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525
PloddinPedro
PostPosted: Mon Apr 20, 2009 5:52 pm    Post subject: Reply with quote
Good thought - tried it and you're right, it does. Thanks.
22.064 (26 Jun 24)
