Posted: Thu Mar 12, 2009 10:19 am Post subject: Icons when selecting a Via Point |
If i Prepare a Route from A to B and then go to enter a Via Point there are coloured symbols next to some of my Favourites (saved as a POI file)
The Blue ones seem to be the start and finish but i can't work out what the yellow one means.
Also does my memory deceive me or is there a green one too? |
dhn Frequent Visitor
Posted: Thu Mar 12, 2009 11:54 am Post subject: |
As I recollect, it has to do with degree of deviation from the main road. Amber would be minimal deviation and I think there is a red one that reflects a major deviation from the main road.
Something like that, anyway ............. _________________ David |
Posted: Thu Mar 12, 2009 12:48 pm Post subject: |
Well that's what i thought but it doesn't seem to bear any relation when i tested it. I'll try again later.... |
Oldboy Pocket GPS Moderator
Posted: Thu Mar 12, 2009 1:44 pm Post subject: |
PaulB2005 wrote: | Well that's what i thought but it doesn't seem to bear any relation when i tested it. I'll try again later.... | The straight blue/green symbol indicates that the waypoint will be within a few hundred yards of the route.
The offset yellow means it's in the right general direction, but could be up to a mile or so off the original route.
The offset red, in older versions, used to indicate that it may not be a viable waypoint as it was way off your route. I don't think it is used now. _________________ Richard
Posted: Fri Mar 13, 2009 12:13 am Post subject: |
Quote: | The offset yellow means it's in the right general direction, but could be up to a mile or so off the original route. |
Ah now a mile makes more sense and confirms what dhn said! I imagined that it meant it was close to the route but not up to a mile. I was thinking a few hundred meters...
However i thought i found a funny instance when i was trying a route out yesterday but I'll have to look later to see what happened....
Thank you Oldboy and dhn. |
