Pocket GPS World :: View topic - Performance between ST to XT modes
matt1971
PostPosted: Tue Mar 30, 2004 11:21 am    Post subject: Performance between ST to XT modes Reply with quote
Have had the Fortuna Clip on for a couple of weeks, and have tried both modes. It is paired with Copilot 4 (v105), Ipaq 3970 and WM 2003
I'm just sharing my experiences whilst driving through central london (Gower St, Covent Garden and Aldwych area)
When using the ST mode the Fortuna never lost a signal, however sometimes the accuracy was way off - perhaps two streets away.
When switched to XT mode, as you would expect the signal was improved and even when I was in traffic with at least 10 story buildings either side still maintained a 3d link.
I have heard that the XT mode cause performance problems delays etc. Well I now leave the fortuna in XT Mode and so far even on motorways doing 70mph + (ahem) has still worked perfectly.
Am well pleased with the Fortuna.
lbendlin
PostPosted: Tue Mar 30, 2004 2:14 pm    Post subject: Reply with quote
Thanks for sharing this experience. Generally the XT mode should only show in phases of acceleration or deceleration. For example when you happen to stop for a traffic light, the receiver may "continue to drive on" for a few seconds before coming back to your position. Same for turns. Driving at constant speeds doesn't normally expose this XT induced effect.
Lutz
TomTom/TeleAtlas NAVTEQ
UHF
PostPosted: Wed Apr 07, 2004 5:55 pm    Post subject: Reply with quote
I have also experenced the lag. I still use it for street nav though. I just watch my route to know when I need to turn insted of waiting for the program to say when. The XT mode is great. I get 11 in view, 10 tracking and fix with 8-9 all the time. I've seen a fix with 11! However, I have never seen 12, the max I believe. I usually run with 12-19 feet accuracy. I've never seen less than 11 though. I'd like to once see single digit accuracy like 9 feet.
bengt
PostPosted: Fri Apr 30, 2004 7:30 am    Post subject: XTmode Fortuna Reply with quote
I have used my Fortuna since jan04 and been travelling around the world with it and used it in much in streetnavigation- Only uses XT mode-and never STmode- It almost never loses fix WHEN it has got it. Accuracy very good and if you know its a small delay it causes no problems whatsoever .
If you start up the GPS eg in the morning after a long idle time in a running car and you have few satellites and weak signals it can take a very long time to get a fix. A Magellan colour (Quad/Helixantenna)at the same conditions gets the fix faster.
On the other hand if you stand still a couple of minutes and get a fix to the Fortuna under those conditions its no problems it almost never loose it.
The Magellan can loose the fix where the Fortuna still has it.
I tested this in Australia in March at least 10 times with both GPses operating when travelling in the rainforests and mountains and a moving Fortuna always had the troubles starting with no fix under severe conditions
http://hem.passagen.se/bigben39/log.htm
Ben
