cartman Occasional Visitor
Posted: Sun Jan 04, 2009 2:46 pm Post subject: GO 530 SD card use |
I've tried following the Help file to initialise the 2GB SD card I have, but can't get my device to use it. Can someone please confirm how I comply with item 5 - "Restore the backup onto your SD card" ? I've selected Memory Card in HOME but it keeps restoring to internal memory. Thanks. DJM |
Posted: Sun Jan 04, 2009 2:52 pm Post subject: |
When you quote "item 5" what set of instructions are you trying to follow, and what do you want to put on your card? - Mike |
Posted: Sun Jan 04, 2009 3:59 pm Post subject: GO 530 SD card use |
Hi Mike
It's from the HOME Help menu, under heading "Using a card reader" & I'd like to transfer my USA & Canada map from my PDA card as the file's too big for the internal memory.
DJM |
Posted: Sun Jan 04, 2009 5:12 pm Post subject: GO 530 SD card |
OK Mike - disregard all - after a bit of tinkering , I've worked it out - I've just used Windows Explorer to read the card in situ & it can see it, so I'll go from there - thanks for replying anyway. Happy New Year by the way ! DJM |
