Pocket GPS World :: View topic - via channel tunnel
via channel tunnel
ben_e71
PostPosted: Thu Oct 16, 2008 10:10 am    Post subject: via channel tunnel Reply with quote
Using 730.
I want to plan a route to a destination in Belgium. What is the best way to do it to ensure it takes me to the channel tunnel and then copes with popping out the other side?
thanks
PostPosted: Thu Oct 16, 2008 10:23 am    Post subject: Reply with quote
Simpler to route to the Channel Tunnel interchange at Ashford and then create a new route from the Calais side.
You can calculate distances by doing an A-B route HOME to Ashford and Calais to Belgium Terminus.
Although I'm sure it defaults to the Chunnel so you may be able to route to your ultimate destination in one go?
emjaiuk
PostPosted: Thu Oct 16, 2008 10:25 am    Post subject: Reply with quote
My experience is that TT chooses the tunnel from SE england by default if set to quickest route. DONT, repeat DONT attempt to follow TT when joining or leaving the train though! (or at Dover & calais) The calculated journey time is suprisingly accurate (under normal circumstances. Even if if you ignore it and take the ferry it reroutes in France as quickly as it does in the UK.
Go740L App 9.510 Europe 985.8155
RDS_TMC mount
Home 2.8.3.2499 Win10 Home
D4VE
PostPosted: Thu Oct 16, 2008 6:22 pm    Post subject: Reply with quote
I pop over to belgium on a regular basis, and i use the ferry not the tunnel.
Darren you are correct in that the default for tomtom is the chunnel.
iPhone4 IOS 4.3.3
TomTom Western Europe v865.3252
App 8.300 V1.6 (670441)
TomTom iPhone Car Kit
PC Operating System: Windows 7
Trevor1234
PostPosted: Thu Oct 16, 2008 7:07 pm    Post subject: Reply with quote
Hi ben_e71
Yes, The Tomtom uses the Channel Tunnel by default. If you plan your trip and then go to Details/ Browse map of route you will see that it does so.
Tomtom Go 720.
Navcore 9.510
Central and Western Europe v855.2884
GPS World Traffic cameras
Home 2.7
iPhone 3G
mpwilson99
PostPosted: Thu Oct 16, 2008 8:49 pm    Post subject: Reply with quote
If you play the demo at 100% when you leave Folkestone to Calias ( or vice versa ) , it is almost exactly spot on. You come up out the tunnel about 2 mins after you have hit dry land.
Try it next time you go !
MPW
TomTom 700 GO user since Dec 2005.
TomTom PDA XDA user since Dec 2007.
TomTom HTC HD2 user since Jul 2012.
ben_e71
PostPosted: Fri Oct 17, 2008 6:19 pm    Post subject: Reply with quote
thanks
GP-YES
PostPosted: Fri Nov 14, 2008 3:07 pm    Post subject: Reply with quote
I am using CoPilot 7 and when I create a trip in Central it automatically takes me through the tunnel but I want to take the ferry. Does anyone know how to change this so it is routed from Dover to Calias?
PostPosted: Fri Nov 14, 2008 3:35 pm    Post subject: Reply with quote
GP-YES wrote:
Can't you just create a route to the Dover Ferry and then repeat on the French side to your destination?
eyeQue
PostPosted: Fri Nov 14, 2008 3:54 pm    Post subject: Reply with quote
Here are the locations needed for routing:-
Ferry-Dover N51.12865 E1.33673
Ferry-Calais N51.12771 E1.33711
Garmin Oregon 300 + Garmin iQue 3600
My Zoned Speed Camera Icons, available here.
Wazza_G
PostPosted: Fri Nov 14, 2008 9:08 pm    Post subject: Reply with quote
You say don't follow the instructions given by the TT when you leave the train, I've always found that they work perfectly, but I do have the warning activated.
